Vidio cam setup
Re: Vidio cam setup
Postby RV4ker (RIP) » Tue Nov 11, 2008 7:43 am
Trikenut wrote:RV4ker,
Can you give me a direct link to then Achros video recorder? The link in your previous post takes me to a model difernt to yours? A internet tablet me thinks! :?
Also, as per my previous post, does anyone know of switch boxes? Sites please?
Can some one please explain to me how the whole recording from a Mini DV (tape) camera through a switchvbox and then onto an external Hard drive e.g. RV4ker's Achros??? Help! :oops:
Ross
Drop me an email and I answer all questions...
Switch box from any security cam shop, or online (cheaper).
Basically the Camera has RCA cable which plugs into the AV in on the Camera (not all camera's have these). Press record on the video camera selecting AV in as source. If you have more than 1 camera you use switch box to select which input goes to the video camera. Simple as that then it on Mini DV tape. Then plug USB or firewire into PC and download the miniDV to PC. Select quality (high - HUGE) and convert to AVI, Mpeg or MP4...
Similar with Achros.
Just plug RCA into Achros and press record. It already in AVI format so just copy to PC...
Massimo
Re: Vidio cam setup
Postby Massimo » Thu Mar 25, 2010 4:40 pm
Ok guys ive pulled up an old post. All the info here is very helpful but its got to be easier.
Is there not one nice BIG shop i can visit in JHB, walk in and an hour later walk out with all the kit ready for installation.
Want to install 3 bullet cams, plus be switachble between cams and record.
cobra
Re: Vidio cam setup
Postby cobra » Thu Mar 25, 2010 5:02 pm
Massimo wrote:Ok guys ive pulled up an old post. All the info here is very helpful but its got to be easier.
easy, buy 3 camcorders, strap them to the wings, switch all on, and edit afterwards
http://www.datatoys.com/products/Specia ... index.html
http://www.4kam.com/
Alkemac
Re: Vidio cam setup
Postby Alkemac » Fri Mar 26, 2010 2:20 pm
Mine is a "made for purpose" type setup.
I took a piece of angle iron 4" long, and welded a piece of flat bar onto the closed side, so I can use cable ties to secure it anywhere on the profile tube. On the inside of the angle iron, I put two strips of single sided tape, which cushions the bracket, reduces vibration and protects the profile tube from being scratched. I also drilled a small hole at the opposite end of the flat bar, so that I can bolt the Panasonic SDR-S15 onto it, and the beauty of it is that I can start the camera at any point of the taxi from the power bloc, and stop it at any point after landing.
What I have found is that when it is lower down the profile tube, you get a lot of movement on landing, as it is almost the lowest point on the pendulum under the wing.
Works for me.. vhpy
ZU-DODO
Big-D
Re: Vidio cam setup
Postby Big-D » Fri Mar 26, 2010 2:34 pm
I gor one of these
http://www.goprocamera.com/
Comes with lots and lots of brackets from helmet mount to bar mount
Quality is unreal and true HD
Lens is fisheye and shoots the angle you see with your eye - Pretty cool stuff
D
Big D
cobra
Re: Vidio cam setup
Postby cobra » Fri Mar 26, 2010 2:40 pm
Also very good products - agent in PE
http://www.vholdr.com/contourhd/helmetcam
Users browsing this forum: No registered users and 26 guests
