Behind the times I seegertcoetzee wrote:Ah something a Jozi will not understand. This is Cape Town Time.. By the way Gert, I see on your track log that you have put in "UTC -2", we are UTC+2, 2hrs ahead of Grenwich.
Morpheus is quite correct with "magnetic variation +/- 23 degrees".ACE wrote:I got into my GPS setup last night and found that it was set to "true North" so I reset it to Magnetic. The current magnetic deviation is 18degrees, a big difference to your heading isn't it
Yep, if you look at the aviation maps you will see the "variation" (thanks John) lines running across the map( these are dashed lines running across the map at an angle with "18deg W" written on it for example As you move south the variation increases. If you are using a map for navigation, you would use the value from the variation line closest to you, i.e from your current position the 18 deg variation line is just below you and the 17.5 is above but further away. You would use the 18deg for the calculation. The GPS does this all automatically.ACE wrote:My GPS automatically came up with 18 degreeswould this be attributed to our different geographical locations
ACE wrote:... The current magnetic deviation is 18degrees, ...
