i dont know what id do without your input
thanks Tumbleweed..have checked connection and seems intact......will try putting in a new battery...although the one on board is "supposed" to be new...ive been told it could be the starter relay..but cant see the relevance of that.the instrument panel tells me low voltage, over volts with the motor running and the battery totally disconected....will try the process of elimanation method but would prefer a cheaper method by asking all the whizz kidds on this forum for advise first....Tumbleweed wrote:Can't see if it's a Raptor, but I've previosly had the main power supply plug to the pod develop a loose connection.
