Trike Tumbling
Henni
Postby Henni » Wed Nov 14, 2007 11:21 am
lamercyfly wrote:Hi Henni...........you just be careful of getting complacent in your 3 axis........there are as many monsters waiting for the careless pilot....and the not so careless.........
So true! Never thought of it in THAT way, but yes, I have to agree with you - every design also has it's pitfalls.
Keep well,
Henni
FAWGie
Postby FAWGie » Wed Nov 21, 2007 8:38 pm
I've got 2 whip stall vids taken of trikes...I get the shivers every time I watch them....
Postby Boet » Sun Feb 03, 2008 7:43 pm
After having seen a trike tumble, I have since politelely refused ever to get on board one. :shock:
emil
Postby emil » Mon Feb 04, 2008 7:22 am
lamercyfly wrote:Hi Henni...........you just be careful of getting complacent in your 3 axis........there are as many monsters waiting for the careless pilot....and the not so careless.........do you know how quickly you can get into a flat spin and in what situation this can happen...........most fixed-wing's are doomed once they enter a flat spin, and what about torque rolling if you are low and slow with a high nose attitude and you apply full power and the environmental conditions help a little by a little thermal under the upgoing wing,.........and over you go, inverted, ........into a spin from which your aircraft cannot recover......... and control linkage failure.....a common occurence in fixed wings (my control linkage is a simple base bar)........
Anyway, fixed wing is lekka, so is gyro, so is hang glider etc., all lekka, but none of them if fool-proof.........so enjoy and take care and be careful other wise it WILL bite hard... :wink: :lol:
Regards.
you are so wrng about the flat spin...most planes CAN NOT even spin ...a flat spin is an aerobatic move...you have to FORCE a plane ..even like a Extra or Cap or one of those to flat spin...it DOES NOT just happen
Biggles
Postby Biggles » Tue Feb 12, 2008 4:17 am
Getting back to trike tumbling. The most common way of getting into one is stalling while in a nose up attitude. Firstly you shouldn't be in that situation but going "shoot-ups" and climbing away from the field too steep and experiencing a loss of power can lead to it. I suppose a stall at low enough speeds and with the wing in could do it aswell.
I was taught to keep the wing forward and then when the wing is level turn off to the side. Resist the temptation to pull the wing in.
Trike pilot
ZU-DLP
Winelands FAWN
