Also make sure you have the correct documentation in the aircraft, as per the ANR's:IceAge wrote:5) What else is required to ensure that we as pilots are 'legal' ????
DaveDocuments to be carried in aircraft
10.4 (2) An aircraft engaged in flight within the Republic shall carry the following documents or photocopies thereof:
(a) Its certificate of registration;
(b) its certificate of airworthiness;
(c) the appropriate licences for each member of the crew;
(d) the aircraft’s radio station licence;
(e) a certificate of safety for flight;
(f) an approved flight manual or equivalent;
(g) approved mass and balance data;
(h) a flight folio;
(i) an approved minimum equipment list, if applicable; and
(j) a list of visual signals for use by intercepting and intercepted aircraft.
