BMW GS1200 motor
Oupa-G
Re: BMW GS1200 motor
Postby Oupa-G » Fri Oct 03, 2008 9:56 pm
That is the sort of figures one gets to. It all depends if you get your second set of injecters new or second hand . The nice part is you can get everything from the engine suppliers. The rest of the stuff we have all in stock.On the E-boxi supply we control every step from design production of the motherboard and the assembly line and the testing. For knowledgable people the box can be tuned with Windows. For the not so electronically minded please leave it to the experts.Any questions contact me on 0849753331
Regards Oupa-G
grostek
Postby grostek » Sun Oct 05, 2008 10:08 pm
Oupa-G wrote: For knowledgable people the box can be tuned with Windows. For the not so electronically minded please leave it to the experts.
Regards Oupa-G
Hi Oupa G,
Can you please tell me what this "tuning via windows achieves?
Kind regards,
Gunter Rostek.
Oupa-G
Postby Oupa-G » Sun Oct 05, 2008 11:04 pm
We tune the box with a basic running program and it is made so that it can be fine tuned by a Lambda sensor. To keep it simple we are sticking at this stage to a basic program.
Not having a Lambda sensor means you can run avgas when that is the only fuel available. If the aircraft is suitably equiped EGT'sthen a adjustable mixture can be installed and the airframe prop combination can be fine tuned and stored in its memory. This process can be traced adjusted and stored with the hyperterminal in Windows. If somebody is not a fundi we prefer to leave things alone. It is not difficult with detonation to burn holes in pistons Gunter I hope this answers your question
Cheers Oupa-G
MYR
Postby MYR » Mon Oct 06, 2008 9:36 am
Oupa-G :
What's the ratio of the gear box ?
I'm a French speaking person. Sorry for the mistakes I can make.
If you don't understand what I say, do not hesitate to tell me.
Je fréquente aussi le forum : Le forum des ULM-ELA-LSA
Oupa-G
Postby Oupa-G » Mon Oct 06, 2008 8:52 pm
MYR it is 3.2:1
Regards Oupa-G
grostek
Postby grostek » Mon Oct 06, 2008 11:18 pm
Oupa-G wrote:We tune the box with a basic running program and it is made so that it can be fine tuned by a Lambda sensor. To keep it simple we are sticking at this stage to a basic program.
Cheers Oupa-G
Hi Oupa G,
Yes it does and thank you.
Kind regards
Gunter Rostek.
Stephan van Tonder
Postby Stephan van Tonder » Wed Nov 26, 2008 11:18 am
Any updates on this motor setup. Could be a worthwhile setup to try in a cheetah. Rattex price is becoming insane now.
Mike Cordeiro
Postby Mike Cordeiro » Thu Nov 27, 2008 8:28 am
Here`s some photos of a Raptor with a Take-off Box and fuel system.
This motor is from an R100S. On a trip to Moz. we averaged 7.4Lt / Hr while the 582 Cobra was burning 17Lt / Hr
The new R1200GS motor is fitted with an internal balancing shaft and it is turbine smooth.
"Take off " also supplies a dual ignition system forthe new motor.
bmw trike.jpg (88.53 KiB) Viewed 3796 times
Stephan van Tonder
Postby Stephan van Tonder » Thu Nov 27, 2008 3:34 pm
Nice install there mike. IS the engine management on that one the bosch original or also from take-off?.
Mike Cordeiro
Postby Mike Cordeiro » Tue Dec 02, 2008 8:37 am
Stephan van Tonder wrote:Nice install there mike. IS the engine management on that one the bosch original or also from take-off?.
The engine management on this one is straight out of a R1100S " Bosch" The wiring harness was made by Take-off to suit the instalation.
Sukkelaar
Postby Sukkelaar » Tue Dec 02, 2008 6:12 pm
Hi Mike
Could you notify as to price? and horse power?
I need a motor asap
Sukkelaar
Kyk Noord
kloot piloot
Postby kloot piloot » Wed Jan 14, 2009 10:23 pm
Mike Cordeiro and Oupa - G, and any others involved with BMW motors. You might have followed my accident of last Friday with my seized Rotax 503 on ZU-AZP (refer Accident forum). My intention is to get AZP going a.s.a.p. to get in the air again. But the incident got me thinking, left many options open and this is where I need your advice.
I am in a position where I can buy a zero hour Take off BMW 1150R complete with starter, alternator, slipper clutch, gearbox, stainless steel exhaust and silencer, oil cooler and oil instruments. Ready to install except for engine mounting brackets. Price is good, machine is in South Africa.
What are my options ?
ZU-AZP is a Windlass undercarriage with an Acquilla wing.
Option 1: Install the BMW in the above configuration, can the u/c and wing take this ?
Option 2: Get AZP going with 503 and start a seperate project with the BMW engine on another second-hand airframe,
Option 3 : Buy a Jenya performance topless wing and find a suitable undercarriage for speed, and build the 1150R in there.
My purchase option on the engine expires in 5 days. Please advise !
Thanks in advance, I don't want to miss this oppurtunity on the motor.
Roel
Roel Jansen
ZU-IAR powered by BMW 1200
kloot piloot
Postby kloot piloot » Wed Jan 14, 2009 10:32 pm
P.S. The BMW total wet weight comes in at 76kg compared to the 503 with E-box at 39 (?) kg.
Roel Jansen
Postby Boet » Wed Jan 14, 2009 10:38 pm
BUY IT!!
kloot piloot
Postby kloot piloot » Wed Jan 14, 2009 11:14 pm
Boet, 50G is a lot of money, but if you say so, I will have that engine in my garage tommorow night. Thanks for a positive reply.
Roel Jansen
