Brass monkeys
cobra
Postby cobra » Thu May 24, 2007 5:15 pm
andreb wrote:Anyone know where I can get the bar-mitts? quickly....
Try Fred 083-256-1873 at Spring Airfield, his school is next to Rainbow Aircraft
andreb wrote: quickly....
A 20 min frost-bite flight :shock: or a 35min drive :wink:
Postby Tumbleweed » Thu May 24, 2007 5:15 pm
Aviation Engines, Germiston.
DieselFan
Postby DieselFan » Thu May 24, 2007 5:24 pm
Lets see I had the oven gloves - the oness that hook on bar, plus first ascent snow gloves with a double inner lining and I can promise you now after 30 mins, there is now feeling left.
I think this is a freak cold front, check out the Durban pics!
Postby Boet » Thu May 24, 2007 7:38 pm
These humans.....they MUST be crazy (**)
cobra
Postby cobra » Thu May 24, 2007 9:07 pm
DieselFan wrote:Lets see I had the oven gloves - the oness that hook on bar, plus first ascent snow gloves with a double inner lining and I can promise you now after 30 mins, there is now feeling left.
Nothing to worry about :roll: DF at 4 deg C and cruising at 55 mph the windchill is -5
If the temperature is -10 deg C and cruising at 55 mph, the windchill is -24 deg C. Only then exposed skin can freeze in 30 minutes which causes frostbite :wink:
We need a serious drop in temp to -10 deg before flying is a no go :D and remember keep your flying time less than 30min :wink:
andreb
Postby andreb » Thu May 24, 2007 9:47 pm
Thanks Cobra.
The weather looks a bit warmer for Saturday (min 6C), so let's hope I don't need the bar mitts. :?
ZULU1
Chill Cheaters and Bar Mitts
Postby ZULU1 » Fri May 25, 2007 7:53 am
Rob Allen Spearguns in Durban makes bar mitts from Neoprene. If enough interest I can contact him to arrange some more manufacture ??
As a add on to our very popular visor bibs I have made some "sleeves" we call "Chill cheaters" with the exact same design as the Royal Navy use for flak bibs, but out of fleece. Same material as supplied to our popular clothing brands. They have a stiff neoprene back to prevent the neck from sliding down. The Royal Navy did the development of this one for me... The sleeve has a Velcro tab on the four corners to secure on a sweater before the flying suit is put on. The neck of the flying suit seals it as they cover the chest and back.
The Royal Navy started (and I) finalised the development. I made them to mate with the visor bibs. These fit on Buzzcom, Lynx and Speakease helmets.
We sell them as individual or as part of a kit either from ourselves or our distributors.
Chill cheaters in red or black, bibs in black or white all ex stock.
In our testing they steam up so the visor has to be lowered just prior to take off, they completely eliminate wind in to the helmet.
Picture shows our helmet. The unit is designed such as the cups are attached to the helmet which allows this to sit much lower reducing cold air in.
aMakaza Zulu1
Chill cheater.jpg (29.3 KiB) Viewed 1051 times
DarkHelmet
Postby DarkHelmet » Fri May 25, 2007 12:05 pm
Zulu1 - that guy in your pic (is it you?) really has a face for radio! Please don't publish that photo anywhere else ;)
Sillyness aside:
I have a visor with bib supplied by yours truly and it is awesome! Problem is the fitting to the XL Buzzcom helmet I have - the outer screws come loose and then you have a dangerous flapping visor mid flight!
I will be ordering an orange helmet, visor, bib combo soon! Hyena made off with my budget!
