Aquilla 582 price
Kalahari pilot
Re: Aquilla 582 price
Postby Kalahari pilot » Thu Sep 14, 2017 5:55 pm
Hi all
So I invited an AP to come and have a look at the trike... only one mod is needed... the nose piece safety cable is not installed..
All rubber and grommets need to be replaced so it should not cost to much to get ATF.
But he suggested to offer only R35k as its an 1999 model. And only 160h left on the engine. ( 1year and maybe 3 months )
Any other offers that anyone would suggest?
von
Postby von » Fri Sep 15, 2017 6:11 am
..... Or you can come buy my Raptor with 182 hours, ATF in place, blue top 582 that is being flown weekly with no hassles for R68000?
At least you know everything is in working order instead of making an offer on something that might have surprises!
072 705 7581
Kalahari pilot
Postby Kalahari pilot » Fri Sep 15, 2017 8:21 am
I like ur trike alot von...
But those instruments is bothering me.. my instructor has 2 sets of those combination instruments in his office as a display unit because it cant be fixed in SA... or do you have a contact if it needs replacement?
Postby Madman » Fri Sep 15, 2017 12:20 pm
The DX2 and the other instruments are serviceable here in Gauteng by Serge from Amptronic ##
I love the DX2 and have never had any issues with mine :mrgreen:
DX2
Pod completed
EGT
skybound®
Postby skybound® » Fri Sep 15, 2017 12:25 pm
Also check the silver top serial number. There were a few that had an issue with a pin or something on the crank. There is a service bulletin about it.
There was also a difference in the crank between the silver and blue top - in particular the crankpin on motors with serial number before 4,172.665 - which are mainly silver top 582s.
There was a service bulletin which covered the replacement of cranks in many of the silver tops with a new version as contained in Service Bulletin 7UL94 issued by Rotax.
von
Postby von » Sat Sep 16, 2017 6:25 am
Hi, yes they are serviceable, but I have never had any issues with mine.
Still even if you replace it, which is not necessary, it will be alot cheaper and easier than buying an engine you are unsure of that might need a redo or replacing...
Wingover1
Postby Wingover1 » Sun Sep 17, 2017 7:35 am
My 2 cents as far as I know you get specific fuel hoses for fuel containing 2 stroke please correct me if I am wrong?
ZU - ATE Windlass 503
ZU - CHG Aquilla 582
ZU - BAJ Bushbaby
