Manie se Raven
Re: Manie se Raven
Boet, sê vir Manie as hy my nie laat weet wanneer die Raven terug is in Pools, nie gaan ek hom nooit vergewe nie.
Lyk ongelooflik mooi!!
Re: Manie se Raven
Daar kort n gezos of twee deur die voor kant van cowl. Hoop daar is iets wat parafien reuk afgee ook iewers ingebou
- Induna
- Nothing beats flying
Re: Manie se Raven
Dit lyk sommer spoggerig! Manie, ou vriend, jy het n baie mooi aerie gebou... Boet, nog n ou vriend, jy het hom baie mooi ge-finish!
Manne, julle kan trots wees op jul gawe vir sulke mooi handewerk!
Jacques
Jacques
ZU-RHT | Magni M18 Spartan
Re: Manie se Raven
Yislike manne maar dis mooi. Staan nou bietjie trug en neem n mooi vol foto vir ons.
Re: Manie se Raven
Ou Man, Dit lyk vir my ek moet meer aeries aanskaf dan gaan jy minder hier verby ry sonder om in te loer...Hahahahaa.
Yes, Boet did some excellent work here. A lot of sweat went into the cowl, and luckily he could bring forward with his handywork what I was visualizing in my head. After I have installed the engine and radiator and oil cooler as they do on the Zodiac, with the radiator under the gearbox and oil cooler under the sump, Boet looked at it and said he have better plan for getting the "turbine" look and moved the radiator to the righthand side and the oil cooler under the gearbox. Must say that he did a very good job here and we'll have to see in flight testing what the temperatures will be doing, but at this stage it looks like we might have to close up some of the airflow so that it does not run too cold. Boet will probably upload some photos of the NACA duct for the radiator on the RHS.
But overall I'm am so pleased with his paintwork, which also was a 50/50 input from us both on the design and his wingroot fairings that he fabricated. I will test fly the aircraft first without the wheelspats and wingroot fairings and after some good documented figures, put them on the aircraft and test the improvement or not of these items on the performance of the plane.
Boet, thanks a lot, man!
Life- I did it my way.....
The world is not enough!
- Manie Rossouw
- Manie Rossouw
Re: Manie se Raven
Plesier ou maat. Dis lekker om vir jou iets te doen!!
Re: Manie se Raven
Hi Boet
Dit is 'n baie mooi "cowl". Ek geniet dit om na jou projekte te kyk.
Hoe maak jy die wheelspats
Re: Manie se Raven
Boet Hi
Kan jy spats vir n Savannah maak ?
Groete
Pieter Roux
Groete
Pieter Roux
Re: Manie se Raven
T-Bird, van glasvesel.
Re: Manie se Raven
Ja ek weet glasvesel.
Maak jy n ook n hout struktuur met n "plug" en dan n negatiewe mold.
- Air Hog
- The Boss
Re: Manie se Raven
Jis Boet, mens sou kon sweer jy het al voorheen met veselglas gewerk.
Re: Manie se Raven
T Bird, jy van n n stuk poly urethane foam, en skuur hom tot sy mates reg is, enmaak dan n "Plug" van hom. Maak lekker dik mold bo-oor, sny oop en jy het jou twee helftes. Maklik.
Re: Manie se Raven
Hogman, het so n paar goetertjies gemaak so oor die jare.
Re: Manie se Raven
Postby lambada » Sun Aug 30, 2015 7:22 am
Boet Hi
Groete
Asseblief................Oom Boet
Boet Hi
Groete
Re: Manie se Raven
Boet wrote:Hogman, het so n paar goetertjies gemaak so oor die jare.
Jean.
