Radio noise at high rpm...
IceAge
Re: Radio noise at high rpm...
Postby IceAge » Mon Mar 31, 2014 9:06 am
Did the following over the weekend:
1) Charged the radio with the supplied charger. Will do this more often
2) Removed the intercom system and cleaned all the electrical connections
3) Removed and cleaned the sparkplug caps, ie. unscrewed the caps from the lead wires, cleaned the insides and screwed them back on ensuring they made good contact
4) Cleaned the headset jack points
5) Verified that the radio squelch was set to 7
The result of this exercise was awesome........... I was able to fly in perfect silence without any interferance......... heehaa. (^^) (^^) (^^)
The only problem I still have is the red and white radio tower on the Magalies........ ## ## ## I pick up radio stations whenever I fly closer than 2 miles and above 5000feet. Solution.... fly low and try to prevent flying close to the tower.
Thanks for all the suggestions
Caught a dream............
Windlass Aquilla
Thunderbird MKII
Savannah VG
Postby nicow » Mon Mar 31, 2014 10:21 am
IceAge wrote:Did the following over the weekend:
Scorpio
Postby Scorpio » Mon Mar 31, 2014 9:43 pm
ZULU1 wrote:Been out of action but just picked this up...try one of these fellows across the battery/regulator
http://www.mantech.co.za/ProductInfo.aspx?Item=72M0037
That should work...
Hi ZULU, Where must this cap. be connected? before the regulator,,,between the engine and the regulator,,, or after the regulator,,,, like across the battery terminals.Using a 582.
Thanx, Kobus
Thunderbird
Bushbaby in rebuild
johnythelaw
Postby johnythelaw » Wed Apr 02, 2014 9:11 am
Hi Everyone
I have the same problem on my 582 engine with MGL V6 radio.
Single seater but the intercom is part of the radio and not in use.
Cannot find any capacitor installed anywhere.
Where must this be installed- On the charging side of the battery or ?
The radio is directly connected to the battery as per MGL instructions
Any suggestions
thanks
Johan de Wet
weedy
I hate bird strikes
I hate bird strikes
Postby weedy » Wed Apr 02, 2014 11:18 am
A capacitor of 22,000 uf 25V should be connected between the B+ terminal of the Voltage Regulator and ground as close to the regulator as practical.
Claude
Postby nicow » Wed Apr 02, 2014 12:52 pm
weedy wrote:A capacitor of 22,000 uf 25V should be connected between the B+ terminal of the Voltage Regulator and ground as close to the regulator as practical.
(^^) (^^) =D*
johnythelaw
Postby johnythelaw » Wed Apr 02, 2014 4:35 pm
HI Claude
I found the one and only person in Swakopmund Nmaibia that work with this stuff.
His question is - must it be exactly 22,000 uf 25V as he can supply me with an 20,000 uf.
He can make some up by soldering units together in series.
Will this be fine
regards
Johan de Wet
vanish
Postby vanish » Wed Apr 02, 2014 6:33 pm
mr law, unto this field of greatness that stands in darkness from our side, more is better, less not so good, so rater hit oversize than under
wish u luck
steve
weedy
I hate bird strikes
I hate bird strikes
Postby weedy » Thu Apr 03, 2014 6:46 am
Hi Johny, that should work fine, the 22,000uf is rotaxes recommendation not cast in concrete, voltage can also vary a bit, 25 - 38 is typical.
Claude
Postby Boet » Mon Apr 07, 2014 6:26 pm
Re-route the ground wire from the battery directly to the engine block. (IF it has not been done.) Ground the engine to the rest of the plane. Take the radio power directly,( thru a seperate switch and a 2A fuse) from the battery. The comms should now be crystal clear. Works for me, every time. vhpy
Postby nicow » Tue Apr 08, 2014 8:08 am
Boet wrote:Re-route the ground wire from the battery directly to the engine block. (IF it has not been done.) Ground the engine to the rest of the plane. Take the radio power directly,( thru a seperate switch and a 2A fuse) from the battery. The comms should now be crystal clear. Works for me, every time. vhpy
Postby Boet » Tue Apr 08, 2014 8:29 pm
vhpy Nico, I presume this works for you? :wink:
Postby nicow » Tue Apr 08, 2014 8:43 pm
Boet wrote:vhpy Nico, I presume this works for you? :wink:
Die gronddraad het my al baie kopsere gegee (**) .
Tinkerbell
Postby Tinkerbell » Tue Apr 08, 2014 9:04 pm
Some of you have mentioned the red and white mast on the Magalies. I recently had a big fright when the radio made so much noise that I was scrambling to get my handheld. I also unplugged my headsets and replugged, switched on and off, even changed the batteries for the noise reduction, but then suddenly everything was back to normal. We had some problems with distortion recently that was resolved when we moved the aerial further from the headset jacks, and I was worried that something else could be wrong now. But during the whole trip I had no other radio problems until on my return I experienced exactly the same problem in exactly the same spot. I immediately realized that it had to be the tower. The strange thing is that I have gone past the mast before in another aircraft, same type radio, and it didn't happen. I was higher than 5000ft as I was crossing the ridge and closer than 2 miles to the mast. Now that I know other people have experienced the same or similar problem I know to avoid it or just ride it out but I was in a total panic when it happened the first time.
ZU-RKU Zen
ZU-RTM Calidus
mulderpm
Postby mulderpm » Fri Apr 18, 2014 4:49 pm
Transmitters are not clean....they emitt spurious radiation...at frequencies other than the fundamental (harmonics). The levels of this spurious radiation is strictly controlled during Type Approval (certification) of the radio equipment. However many conditions, post Type Approval, affect spurious radiation. Weather, bad earthing, mismatches, all affect this phenomena. If you are close to a high power transmitter, the red & white tower, you may experience spurious radiation which affects our airband receivers, in the 118 to 136 MHz band. (**)
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
