PETROL FILTERS.......AGAIN!! But please look
John Young
Postby John Young » Mon Jul 22, 2013 11:24 pm
mulderpm wrote:Rotax specifies that the fuel filter must have a mesh size of 0.15 mm and must be fitted between the pump and the carburetor.
The Rotax spec is 0.5mm.
99.9% of in-line filters are fitted between the tank and pump. I wouldn't put a fuel filter into a pressured line (between pump and carb).
Regards to all from a HOTTT Florida. (^^)
John
Re: PETROL FILTERS.......AGAIN!! But please look
Postby Jean Crous » Tue Jul 23, 2013 8:07 pm
I agree with John, is the idea not to keep the dirt/contaminants OUT of the working parts ?
Filter BEFORE the pump is also my rule . :wink:
Jean.
ZU-Nathan
Postby ZU-Nathan » Wed Jul 24, 2013 1:12 pm
Hi.
I agree with the inline filter discussion in general, personally I also do not use paper type inline filters as I am running pre-mixed two stroke fuel.
What concerns me is ... how often does the strainer/filter in the tank get cleaned or replaced. It is not visible on pre-flight and also probably not a good idea to remove the screws to often as they are screwed into the plastic tank to clean it?
Nathan
ZU-EFN
Aquilla
ZU-KYK
Cobra
Flying just got better!!!!
Postby Morph » Thu Jul 25, 2013 10:36 am
Not sure of the Aquila even has a strainer. They are usually installed into planes where you cannot look into the tank. You should be able to look into your tank and see any large debris in there like leaves. If take the take out and rinse it out
Postby Bundy » Thu Jul 25, 2013 1:17 pm
Morph wrote:Not sure of the Aquila even has a strainer.
Yip...it does. :)
I only know because our tank was emptied and cleaned when we rebuilt ^
Postby Morph » Fri Jul 26, 2013 9:11 am
Excellent
Last thing you need is a leaf spoiling your day
Postby Boet » Fri Jul 26, 2013 3:48 pm
That is why ALL petrol tanks on aircraft should have a sieve at the petrol outlet point. That way "one leaf" can`t ruin your day!!
REDROMAN
Postby REDROMAN » Thu Sep 19, 2013 7:37 am
Mercedes Filter - the Best
ZU-BMZ
Aliwal North
Postby Boet » Fri Sep 20, 2013 10:27 am
And now I was told that the MB filter/sieve is no longer available, but fortunately the aftermarket part is still available, unfortunately, without "hose barbs". :roll: :roll: ## ## ## ## ## ## ## ## ## ## ## ##
nickjaxe
Postby nickjaxe » Fri Sep 20, 2013 8:47 pm
I wonder if anybody know the filter spec of the glass one...is it less than the rotax 0.15mm spec
p3tr
Postby p3tr » Sat Oct 12, 2013 5:20 pm
so quick question:
regarding filter positions. for an auxiliary fuel line. in that case, the life of the electric pump is not a major concern since the pump is only used rarely.
as an option to NO fuel filter on the auxiliary line to get clogged, could it be more reliable to fit the pump before the filter, so as to avoid vacuums etc. forming downstream of the filter were it to get a bit clogged? that way one has positive pressure on the filter, which is more likely to find a way through the filter when one needs it to than suction?
or am i missing something critical about fluids and pipes?
ZU-DFM
Turbo
Postby Turbo » Sun Oct 13, 2013 8:57 am
If your fuel filters are getting blocked and contaminated, then you potentially have a huge problem if you flying a 912 -- the pump on the gearbox of the 912s also have a small fuel filter inside, and these pumps are sealed and not serviceable..... Always make sure your filters are clean!
p3tr
Postby p3tr » Sat Oct 19, 2013 2:17 pm
OK thanks for this, i will make sure of it. i would not consider running my motor without a filter.
suppose in that case it has no advantage playing around with the auxiliary line's filter position either, since if the filter is contaminated one would lose the motor anyway.
so wherever the pump / filter sits comes down to the same thing, other than pump life were it to sit ahead of the filter.
i imagine the filter doesn't do much work if one uses clean fuel which hasn't been carried across the mountain with donkeys so the pump life would probably be long regardless of where it sits?
ZU-DFM
