Medical Examination - which is right?
Hi UJOHN,
You are quite right, it is called the PSA test. Unfortunately neither the dipstick test, nor the PSA test is completely reliable. Both tests are complementary. It is therefore best to perform both tests, not necessarily at the same time. My doc recommends to alternate the tests. To my knowledge, if the PSA test is high, it does not necessarily mean you have a prostrate problem. If you have a bladder infection, your readings can also be high.
Arnulf
Arnulf
- Duck Rogers
Hi UJOHN,
Please note: I am not a medical expert.
Possibly somebody with more specialized knowledge on this subject should give more info.
I never actually thought about it why they focus on the prostate for the flying medical. I suppose the guy doing medicals can give you more info on that. Since I turned 40, I must do a medical every 6 months, and the dipstick test seems more important for the Doc as I get older. Before it really never was an issue. I suppose as one gets older, the risk is increased for prostate cancer. The good news is, that prostate cancer takes long time to develop, and if diagnosed in its early stages it can be cured quite successfull. Also if attended to in its early stages, it should not affect your flying medical. Your love life will probably be more affected than the flying life.
Arnulf
Arnulf
- Duck Rogers
- Thunderboy
- Tumbleweed
- Thunderboy
