Help please! 582 not getting revs
Loco
Re: Help please! 582 not getting revs
Postby Loco » Thu Jan 17, 2013 4:53 pm
Karman wrote:Other things to check:
Ignition Timing (even 0.5 degree will give you big rpm changes)
Carb/s actually opening fully.
Same Air cleaners (some air cleaners allow more air than others)
Same carb jetting (not so easy to check)
Spark plug same type/gap correct
plug leads good order
Resistors on plug caps still fine ( dunno if applicable)
Then of course. ... Same fuel, same oil, same fuel/oil ratio .. etc etc etc
Awesome stuff many thanks we'll go through all these and try eliminate the problem (^^)
Anthony Hugo
Crosswinds
Karman
Postby Karman » Thu Jan 17, 2013 4:57 pm
Found this now as well: Rotax Debug info: http://www.rotaxservice.com/documents/t ... oot2ST.pdf (that is for 2stroke)
German
Postby German » Thu Jan 17, 2013 6:03 pm
Station Kariba wrote:Justin
I read the post :roll: . You cannot assume that if you try a propeller off one Trike onto another that the pitch will be the same. This is not true, as the angle of the hub may differ on both planes, thus altering the pitch angle on the Prop, when you swap them over. The ONLY thing that will effect the RPM on the engine, is the Propeller. I wait with interest to see the results of the findings. Let us know.
Loco
Postby Loco » Thu Jan 17, 2013 8:39 pm
Quick question guys, Ian did a compression test on both trikes
Other trike (standard size pistons) that gets 6200rpm reads 7.5
My trike (new 1'st oversize pistons) reads 7.2
Can't one assume this is normal since its a bigger volume?
And can that be why I'm getting less rpm?!
Anthony Hugo
Crosswinds
Loco
Postby Loco » Thu Jan 17, 2013 9:06 pm
Another anomaly...
Trike A - standard size pistons
Trike B - my trike new oversize pistons
1. A gets 6200rpm with its own prop and exhaust
2. B gets 5800rpm with its own prop and exhaust
3. Ian put A's prop on B, B now gets 5700rpm (100 less so it seems A's pitch is a bit more than B's prop)
4. Ian put A's prop and exhaust on B, B now gets 5850rpm (150 more since last time so it seems A's exhaust is better)
5. Ian put back B's prop so now it only has A's exhaust, B now still gets 5850rpm (so why did we get 100 less at point 3?!)
Eish these Rotax engines are black magic
Perhaps something's wrong with my rpm guage, does anybody have a hand-held rpm guage or something I can borrow just to be sure please?
Anthony Hugo
Crosswinds
mulderpm
Postby mulderpm » Fri Jan 18, 2013 9:57 am
Ant, I am no expert but for what it is worth my thoughts are. The two engines are basically not developing the same power. If the only thing you changed was the rebore, oversize pistons and rings, then I would imagine that running her in for longer will make her looser and she should develop more power over time. In the mean time, to up the loaded revs, make the pitch finer on your prop. Else check all the things mentioned by Karman. (^^) You could also consider swapping the carbs between A and B. (^^)
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
mulderpm
Postby mulderpm » Fri Jan 18, 2013 10:35 am
Ant, my engine max rpm varies by 100 rpm from day to day ## . I attribute this to atmospheric changes. She revs max 6480. 400 rpm difference is not right. Try swapping carbs...it is relatively easy. As you mentioned, try using a hand held tachometer on both A and B. Some timing lights have one built in. If you have EGT's fitted you could compare that as well. Full throttle, max rpm, I get between 610 - 620 deg C, that is with altitude compensated main jets (158). If you get below 600 you are running too rich or your slides are not opening fully. (^^)
Paul Mulder
ZU-DBC Aquilla
Pretoria
Loco
Postby Loco » Fri Jan 18, 2013 10:41 am
Thanks you know where I can borrow/buy a tiny tach?
Anthony Hugo
Crosswinds
mulderpm
Postby mulderpm » Fri Jan 18, 2013 10:52 am
You could try Hans or Alex or a motorcycle tune up place, like Mean Machine or Motorcycle Meca, else Midas or Autozone sells them.
Paul Mulder
ZU-DBC Aquilla
Pretoria
KlapperKnop
Postby KlapperKnop » Fri Jan 18, 2013 10:57 am
anthonyhugo wrote:Thanks you know where I can borrow/buy a tiny tach?
Ant, I have one which I used on RC props.
ZU-DJE
Loco
Postby Loco » Fri Jan 18, 2013 11:02 am
Cool so I should be able to get them at RC hobby shops as well?
Anthony Hugo
Crosswinds
mulderpm
Postby mulderpm » Fri Jan 18, 2013 11:03 am
Hi Faiz, Does it measure prop revs? Then you will have to multiply the reading by the gearbox ratio to get engine rpm...else just compare the prop revs between A and B. I also want to borrow your metertjie, please man. Check if my tachometer reads correctly, for once and for all. Pedantic hey. ##
Paul Mulder
ZU-DBC Aquilla
Pretoria
KlapperKnop
Postby KlapperKnop » Fri Jan 18, 2013 11:07 am
Or you can just borrow mine?
ZU-DJE
KlapperKnop
Postby KlapperKnop » Fri Jan 18, 2013 11:11 am
mulderpm wrote:Hi Faiz, Does it measure prop revs? Then you will have to multiply the reading by the gearbox ratio to get engine rpm...else just compare the prop revs between A and B. I also want to borrow your metertjie, please man. Check if my tachometer reads correctly, for once and for all. Pedantic hey. ##
This measures prop revvs. Tolerance is +/- 10rpm as the LCD display reads RPM actual/10. Will bring it along tomorrow for those that needs to check at ML. This little tachometer has the option for 2 blade, 3 blade and 4 blade ....
ZU-DJE
Loco
Postby Loco » Fri Jan 18, 2013 11:13 am
KlapperKnop wrote:Or you can just borrow mine?
Awesome thanks man! (^^)
Anthony Hugo
Crosswinds
