RPM Rotax 582 limited to 4000?
Dobbs
Re: RPM Rotax 582 limited to 4000?
Postby Dobbs » Sun Oct 14, 2012 3:31 pm
Hi Koos, glad you found the cause of the problem, however, with an engine which has not run for that length of time, hopefully you also inspected the bearings for corrosion and the seals for hardening etc?
