Any comments . . . . as this checklist is now work-in-progress!
e.g. Any suggestions on minimum needed for "Runway Remaining for Aborted Take-Off"? Say at 45mph?
Safe Skies
John
WhiteEagle, where does the 17 degrees come from?WhiteEagle wrote:Here is a quick way of working out your density altitude: say for instance you are 4000 feet amsl. Tempreture outside is 25 degrees. Take 25 - 17 = 8. For every 4 degrees above 17 you add 1000 feet. In this instance your DA is 6000 feet amsl. Hope this help. There are a bit of humidity build into the calculation. There are more accurate ways to calculte the correct DA, but to difficult for me.
Huh........?WhiteEagle wrote:Here is a quick way of working out your density altitude: say for instance you are 4000 feet amsl. Tempreture outside is 25 degrees. Take 25 - 17 = 8. For every 4 degrees above 17 you add 1000 feet. In this instance your DA is 6000 feet amsl. Hope this help. There are a bit of humidity build into the calculation. There are more accurate ways to calculte the correct DA, but to difficult for me.
Dish wrote:ask a chick whose 90 Kgs to tell you shes 90 Kgs !!! wont happen bud, in her mind shes 80....
Or just use one of these.WhiteEagle wrote:Here is a quick way of working out your density altitude: say for instance you are 4000 feet amsl. Tempreture outside is 25 degrees. Take 25 - 17 = 8. For every 4 degrees above 17 you add 1000 feet. In this instance your DA is 6000 feet amsl. Hope this help. There are a bit of humidity build into the calculation. There are more accurate ways to calculte the correct DA, but to difficult for me.
