Rotax 914 Oil
BONZAI BELL
Re: Rotax 914 Oil
Postby BONZAI BELL » Sun Dec 11, 2011 3:14 pm
OzGyro wrote:Hi All
Swannie I would also be very intersted to see whats in the Shell AX-7 your speaking of.
Hi Darren
I do have some AX-7 should you want to test it . also let me know if i must get you a copy of the specs of both these oils.
Swannie
ZU-EOL
Magni M-22
OzGyro
Re: Rotax 914 Oil
Postby OzGyro » Sun Dec 11, 2011 4:48 pm
Hi All.
Swannie, I have downloaded all the spec sheets and on face value I cant see why the AX-7 wont do the job. All we need to see now is how the additive packs compare. Will have to make a plan to grab a sample from you, will give you a call during the week.
Darren
JvTonder
Re: Rotax 914 Oil
Postby JvTonder » Mon Feb 06, 2012 7:37 am
Hi Darren,
Have you tested the AX7 yet and what did you find?
I have some VSX and Activo that you can test, can we maybe make a plan?
Cheers and Thanks
Jaco
Oh eight 3 two eight 7 one five 9 five
Flying feeds the soul!
OzGyro
Re: Rotax 914 Oil
Postby OzGyro » Thu Feb 09, 2012 7:41 am
Hi Jaco
As yet I havent tested the AX-7 but will try and make a plan to get a hold of sum in the next week or so. I have tested the VSX and the New ELF Eco, at this stage my prference would be to stay with the VSX if you can find it. I will give you a call today and we can definitley make a plan to catch up, I would be really keen to see how the Activo stacks up in comparison to the others.
Darren
JvTonder
Re: Rotax 914 Oil
Postby JvTonder » Thu Feb 09, 2012 8:51 am
OzGyro wrote:Hi Jaco
Darren
Will be waiting for your call.
Low Level
Re: Rotax 914 Oil
Postby Low Level » Thu Feb 09, 2012 9:23 am
OzGyro wrote:I would be really keen to see how the Activo stacks up in comparison to the others
With you on that.
For some reason the Rotax boytjies are not keen on Castrol. Would be interesting to know why. I've been running my bikes on Actevo for litterally 100 000's of km's of hard riding, without any issues. In fact I swear that the gearboxes are more smooth with Actevo.....and the most important thing, the price is right. vhpy
ZU-CFW
JvTonder
Re: Rotax 914 Oil
Postby JvTonder » Sat Mar 03, 2012 9:12 pm
Hi Darren,
Any news yet on the test off the Activo?
Jaco
Big Man
Re: Rotax 914 Oil
Postby Big Man » Mon Mar 05, 2012 7:42 am
I also experience a 10 degree increase in temp. after changing from VSX to AX-7..............
I refuse to grow up.
ZU-CKX; ZU-ERN; ZU-LSC
JvTonder
Re: Rotax 914 Oil
Postby JvTonder » Mon Mar 05, 2012 3:24 pm
Big Man wrote:I also experience a 10 degree increase in temp. after changing from VSX to AX-7..............
Hi Big Man,
Did you use the 10W40 or 15w50?
Jaco
Big Man
Re: Rotax 914 Oil
Postby Big Man » Tue Mar 06, 2012 1:45 am
Jaco
I will have to go and check...
OzGyro
Re: Rotax 914 Oil
Postby OzGyro » Thu Mar 08, 2012 3:56 pm
Hi All
Please find attached document with the test results from the oils I have recently tested. Two of the oils (VSX and Elf) are Rotax approved, the third (Castrol Actevo) is not. If anyone has any questions please feel free to ask and I will answer what I can.
Darren
RotaxOils.pdf
(88.94 KiB) Downloaded 233 times
JvTonder
Re: Rotax 914 Oil
Postby JvTonder » Thu Mar 08, 2012 8:46 pm
So their you have it, Shell VSX first and Castrol Actevo second. I will be using Actevo from now on seeing as the viscosity is better at 100 C than what elf is.
Thanks for the tests Darren!
JvTonder
Re: Rotax 914 Oil
Postby JvTonder » Mon Mar 26, 2012 7:48 pm
Hi Darren,
You still in SA and did you get a chance to test the ASX7 15w50?
Jaco
lion
Re: Rotax 914 Oil
Postby lion » Wed May 09, 2012 12:09 pm
Aeroshell Sport Plus 4 is the oil recommended by Rotax for the 914 & 912.
L.
