Postby Gyronaut » Sat Nov 19, 2011 6:16 pm
Thebushpilot, FO Gyro, Vertical Tango and Weedy, I agree with everything you have said.
The only thing I dissagree with the Aussies on is the 8 hours dual cross country for ab-initio. No man, 8 hours?? Sheez, thats a bit much.
On the topic of whether the instructor really has the say or not, I have the following to repeat (forgive me if I have done it before elsewhere). If the instructor feels that the student has control of the machine and will survive an emergency while alone, and subject to a dual check by an independent instructor, then why not. The real test of a confident instructor is one who is happy to send a student solo in his own machines. I have a problem with the logic that "you can go solo on your own machine - but not mine because the risk to my machine is too great"... What about HIS LIFE!? IF you wont send him solo on your own machine he shouldn't be going solo. Klaar. Quite simple really.
As for the discussion about the hours. An outstanding example of how I feel is reflected below verbatim except that I have changed the names of people and places and numbers.
Letter to RAASA from myself,
To whom it may concern:
APPLICATION FOR REDUCTION IN MINIMUM HOURS
NRPL (GYRO)
Mr James Wood, ID: 630123 456 78 approached Morningstar Flight Academy on 24 April 2011 to commence his Gyrocopter training.
He holds an ATP licence and is a Training Captain for XYZ-AIR on Boeing 123’s. He held a CPL(H) and has an LSA/WCM National Pilots Licence # 12345678. He owns a XYZ Compsite Light Sport Aircraft and his experience on this machine is evident in his handling of a Gyroplane.
It soon became evident that Mr Wood understood the airodynamics and controls of a Gyro very well and after a dual check with an independent instructor (Instructor XYZ) he went solo on XYZ ZU-XYZ on 30 April 2011 at FAXX. After a total of 8.0 hours dual and 4.5 hours solo he underwent his final flight test, again with XYZ and passed. He has also written the Principles of Flight and Engines and Airframe exams and passed both, which you will have on record.
It is our considered opinion that Mr Wood, who owns his own XYZ Gyroplane is competent and fully able to safely fly the machine although he has not completed the required 26 hours of dual and solo training.
Considering his vast prior flying experience and his natural ability, we respectfully request that an exception be made in his case and that his Gyroplane licence is issued to him in spite of the fact that he has not completed the minimum hours required.
I trust this request will be favourably considered.
Sincerely
L P KLOPPER
Gyroplane Instructor
123456789
So far so good... then a few days later I get this back from RAASA
Sent: 22 June 2011 10:09 AM
To: 'Cape Recreational Flight Training'
Subject: J WOOD Gyro Application
Hi XYZ.
Re your letter requesting the reduction in hours for J Wood to obtain his Gyroplane license the following:
See:
Experience
62.06.2 (1) An applicant for the issuing of a first type rating in the category gyroplane shall have completed not less than 30 hours flight time as a pilot of a gyroplane, of which at least 15 hours shall be solo flight time, and which flight time shall include –
(a) one cross-country flight, whether dual or under supervision, and one solo cross-country flight, each of a duration of not less than 90 minutes, flown at normal cruising speed; and
(b) one cross-country flight, whether duel or under supervision, of a duration of not lees than 90 minutes, flown at normal cruising speed, and which includes a full-stop landing at a point other than the point of departure:
Provided that the cross-country requirement shall not apply in the case of a type rating to be endorsed ‘tethered flight only’.
(2) The cross-country flights, referred to in sub-regulation (1), shall consist of at least three legs.
(3) Notwithstanding the provisions of sub-regulation (1), in the case of an applicant with extensive cross-country experience as the holder of a pilot licence, issued in terms of this Part or of Part 61, or as a pilot in the South African Air Force, the cross-country requirements may be relaxed at the discretion of the flight instructor who conducts the skill test, referred to in regulation 62.06.5.
Therefore the only credit the applicant may receive is a relaxation on his cross countries, at the discretion of the testing instructor. He would therefore have to complete the balance of the flying hours as required above.
Kind Regards
XYZ
Assistant Flight Operations Manager
RAASA
So, In this gentlemans case, he simply flew the solo hours required with the added hassle of being signed out and back in and we did the dual by doing a lot of the Advanced stuff like Flying behind the power curve, Mountain Flying, Formation Flying, Display Flying and all the lekka stuff. Of course I learned a lot from him too!
Personally I dont think its a big deal, I would propose we keep it as it is for Ab-intio and adopt the Australian method ASAP for holders of Aeroplane and/or Helicopter licences - within 5 years of lapse.
That would get my vote. Perhaps something to be raised at the SAGPA AGM. I will place it on the Agenda.
Len
