Best intercom system.
Porra
Helmets and all..
Postby Porra » Tue Mar 14, 2006 8:26 pm
Hi Bennie, just flew the latest helmet from air magic, this was amazing with a bib to prevent air from the underneath. He has now fitted some fancy imported dual mic system which cuts external noise to zero. It is quite eerie to fly as the cups are strapped over the ears. The guys a bit of a fanatic but his product is very good. I am very happy with the air magic system...Hes quite an emotional character though !!! Very happy.
Jose
Aerosan
Postby Aerosan » Wed Mar 15, 2006 6:46 am
Delta
Me and only ME use my headset and that goes for my buke helmet as well. To me its like a jockstrap, very personal!! :D
Postby Tumbleweed » Thu Mar 16, 2006 4:37 pm
Anyone using the "air Magic' intercom system from Durban?
Had a very positive response from my inquiry.
Lighter helmets, visor can't flap open in flight, has 'bib' reducing noise and that's without noise reduction filtering.
Pity, can't or reluctant to modify Buzzcom system.
Price certainly enticing.
Bennie Vorster
Postby Bennie Vorster » Fri Mar 17, 2006 6:09 am
Hi Jose
Can you maybe post some pictures for us please? :wink:
Bennie Vorster
083 277 5110
Porra
Postby Porra » Thu Apr 27, 2006 8:32 pm
:lol: Hi Bennie, i think if you look under hangar talk quite a way down,you will see a heading by Hazzard "at last an intercom system that realy works". Donald has put some pics in there. :twisted:
Cloud Warrior
Postby Cloud Warrior » Fri Apr 28, 2006 2:06 am
Porra
I must be blind - where are these pictures of the new intercom? I can't find them......
CW
Porra
Postby Porra » Fri Apr 28, 2006 6:12 pm
:oops: Sorry guys. under manufactures and agents info on home page and under the heading " Air magic helmets" :roll:
Postby Duck Rogers » Fri Apr 28, 2006 8:49 pm
My previous plane was a Skyfox with a 503 mounted about 18 inches above my head. What a racket!!
I used a full face helmet and built the earphones and mike in to it. Noise cancelling mike setup is reasonably easy to do and it cut out almost all the noise. Also had a bib fitted to reduce the wind noise.
The earphones (or headset) part was a bit tricky though. I shaped some dense type foam and fitted the earphones into the recesses that was created in the foam. Fitted the whole lot into the helmet and my ears were nicely fitted into the foam recesses. Just like having a headset on :D
Wasn't a wireless setup though. I had the cable coming out of the helmet and it had to be plugged into the intercom. Worked just fine for me :D
