Rotax 914 leaking oil thru air filter
Turbo_Boss
Re: Rotax 914 leaking oil thru air filter
Postby Turbo_Boss » Tue Nov 16, 2010 5:41 am
Hey guys,
Sorry for my late reply. Well we clean the air filter, and remove all the oil in the turbo housing. We start the engine and there was no smoke. I fly it and use it for around 30 minutes and there was not oil smoke.
I put the Magni in the hangar and leave it there to see if it leaking oil but there in not leak any more. vhpy
The mechanic toll me that maybe the (3) PRESURE VALVE got stock open by some carbon deposits in the oil and thats why it was leaking.
I also change all the oil and took out the oil canister to clean it inside. I took the oil filter and cut it with a special tool for this and I check for metal particles on the paper element and it was OK
Until now, there is no leak :P
If this happen again, I will replace the (3) PRESURE VALVE
THX,
Isaac
zucac
Postby zucac » Tue Nov 16, 2010 9:37 am
did you put the motor thru neg."G"
Turbo_Boss
Postby Turbo_Boss » Tue Nov 16, 2010 8:33 pm
zucac wrote:did you put the motor thru neg."G"
Dont undertand what you are asking
Isaac
AndyG
Postby AndyG » Wed Nov 17, 2010 7:34 am
Isaac
After a steep pull up and then pitching forward and down you will experience negative g's(you get lighter in the seat) as will your engine and the oil contained therein.
THI
Postby THI » Wed Nov 17, 2010 10:00 am
Isaac
I agree with Turbo_Boss. I (we) understand what neg g's is, but how can that affect the engine? When you do stalls (training) on a fix wing you experience neg g's regularly. This doesn't effect the engine...or does it :shock:
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
AndyG
Postby AndyG » Wed Nov 17, 2010 11:09 am
I don't know, was just answering the question as I understood it.
Would be interested in the answer (^^)
zucac
Postby zucac » Wed Nov 17, 2010 11:20 am
with my foxbat when I put it thru neg G s I get oil comming out of the sump and then down the side of the plane,the black oil
looks bad and go,s every where.
Turbo_Boss
Postby Turbo_Boss » Wed Nov 17, 2010 8:34 pm
No, No Negative G´s......... Only Positives
Isaac
