3 Blade prop on a 'B' Box ????
Cee Vee Ess
Re: 3 Blade prop on a 'B' Box ????
Postby Cee Vee Ess » Mon May 24, 2010 8:21 am
Apparently this is a good margin. When the prop comes close to the speed of sound then the prop starts oscillating and is unstable, and only after it breaks through Mach 1 it becomes stable again.
Aerosan
Postby Aerosan » Fri May 28, 2010 5:57 am
Cee Vee Ess wrote:Apparently this is a good margin. When the prop comes close to the speed of sound then the prop starts oscillating and is unstable, and only after it breaks through Mach 1 it becomes stable again.
"only after it breaks " herein lies the secret :| I personally do not think anything will be stable if the tip of your prop breaks the sound barrier, but hey thats just me ($$) puff
