coughing 503 dual
Junkie
Postby Junkie » Wed Feb 08, 2006 6:01 pm
Good news Greg..
I also just sorted an issue where one carb was empty and the other normal, discovered a kinked fuel line from the pump - this AFTER my so called "pre-flights" - obviously kak an in a hurry
electric pump saved the day again :shock: =D* #-0
Have rerouted fuel lines (Blue) again to ensure this dont happen again (i realy thought id done a grand job the last time !!)
... simplest things will get u :evil:
J.U.N.K.I.E 's
No credit / No returns
Griffin
Postby Griffin » Wed Feb 08, 2006 6:05 pm
Niren
It sounds as though the float bowl on one of the carbs was empty. I would check the float, needle and seat.
Griffin
Postby Griffin » Wed Feb 08, 2006 6:07 pm
... or a kink in the fluel line :oops:
Aviation Engines
Postby Aviation Engines » Wed Feb 08, 2006 6:24 pm
I've also come across fuel lines that that over tightened causing a crease in the line resulting in the sucking in of air. I may not leak since it's a suction line.
The impulse line from the pump to the crankcase should be as short as possible. the breather the on the pump must face upwards or sideways, never down.
Niren
