serious stuff - serious fo sure Read it now !!!
Re: serious stuff - serious fo sure Read it now !!!
Postby RV4ker (RIP) » Fri Oct 09, 2009 12:39 pm
1:500K map
Looks like only the eastern area is outside and a small section on West? (I don't know the area at all)
Postby RV4ker (RIP) » Fri Oct 09, 2009 12:49 pm
1:250K paints a different picture... (just for some balance)
Postby RV4ker (RIP) » Fri Oct 09, 2009 12:51 pm
Wonder which one is "right".
Fact remains. If the papgooiers "file" a complaint you have a real problem....
Just my 2c....
I like looking at low flying aeries (^^) (^^) (^^)
Dish
Postby Dish » Fri Oct 09, 2009 1:50 pm
Moer but we have debated this topic a number of times now... ## ## ##
RV9
DISH
topflight
Survived first engine out
Postby topflight » Fri Oct 09, 2009 8:05 pm
Yes, but we like it a-lot vhpy
Xyster
Found a flight school
Postby Xyster » Fri Oct 09, 2009 9:15 pm
CAA must stop making tea-time rules. If it is not written into law it is not law. ## ## ##
kloot piloot
Postby kloot piloot » Sat Oct 10, 2009 6:10 pm
Common law would be that the 1:250 map will over-ride the 1:500 map for obvious reasons. In construction law a detail drawing will always over-ride a general floorplan. Why else would the map creators have created a 1: 250 ? To avoid "gray area" debates of course.
It is clear that the Bronkies waterline to water is not a reserve, but the landline to land is.
Roel Jansen
ZU-IAR powered by BMW 1200
Postby Tumbleweed » Sat Oct 10, 2009 7:49 pm
Now the pap gooiers should go for tea and explain why they're fishing in a reserve. :lol:
witwillem
Postby witwillem » Mon Oct 12, 2009 8:23 pm
So saam met die tee en al hoor ek daar was n insident in die noorde die naweek - klink amper soos n traaik sonner n pilot of sonner n flerk - weet iemand iets van dit - wonner net of die tee suipers in kennis gestel is of hoe ,
Willempie
Rudix
Postby Rudix » Mon Oct 12, 2009 8:26 pm
Tumbleweed wrote:Now the pap gooiers should go for tea and explain why they're fishing in a reserve. :lol:
I was wondering about that......
Rudix
Postby Rudix » Mon Oct 12, 2009 8:27 pm
witwillem wrote:So saam met die tee en al hoor ek daar was n insident in die noorde die naweek - klink amper soos n traaik sonner n pilot of sonner n flerk - weet iemand iets van dit - wonner net of die tee suipers in kennis gestel is of hoe ,
Willempie
Dit was sonner 'n vlerk of 'n pilot :shock:
witwillem
Postby witwillem » Mon Oct 12, 2009 8:33 pm
Jis dit raak rof innie noorde - hoe vlie jy sonner n flerk of sonner n pilot ??
Rudix weet jy meer - lat ons hoor wat die manne anvang ?
willempie
Rudix
Postby Rudix » Mon Oct 12, 2009 8:40 pm
witwillem wrote:Jis dit raak rof innie noorde - hoe vlie jy sonner n flerk of sonner n pilot ??
willempie
Jy vlieg maar baie laag soos 'n grondvoel vhpy
Nee, weet nie veel meer nie, net dat "iemand" aan die trike gewerk het, toe die engin gestart het wat ongelukkig full throttle was, en dit sonder die vlerk....
Niemand het seer gekry nie (^^)
IceAge
Postby IceAge » Tue Oct 13, 2009 8:53 am
Rudix,
Check the posting on Accidents and Incident by Dawid.
Caught a dream............
Windlass Aquilla
Thunderbird MKII
Savannah VG
skybound®
Postby skybound® » Tue Oct 13, 2009 10:31 am
kloot piloot wrote:Common law would be that the 1:250 map will over-ride the 1:500 map for obvious reasons.
Not so obvious. I would enter a suggestion that the map that you are meant to have on board would be the one used in determining if you overstepped a boundary. If I recall correctly - it is law to have a 1:1 000 000 aero map on board of the area you are flying.
