Any plastic parts for aircraft Cessna-150/152/170/172/182.
Every month we expand the range of manufactured parts for Cessna aircraft and other common types. We are faced with the fact that the quality of plastic parts is very low. For this reason, plastic parts very quickly crack and fail. We are decisively changing the situation. Our parts are required to work at least 5 years, the normal life-10 years. There is in view tough, harsh exploitation of. In this case, the parts should not become heavier. Try it - compare - verify.
Re: Any plastic parts for aircraft Cessna-150/152/170/172/182
We are expanding the range of parts. We are working on FAA certification.
We continue to make plastic parts for old airplanes. Thanks to their strong and lightweight fiberglass construction, they last as long as possible under the harshest operating conditions.
Users browsing this forum: Google Adsense [Bot] and 4 guests
