Hi all
Anybody have these these parts available, off an old 582?
Pics attached. Need all three, if possible.
Much appreciated.
Lm
0825746102
582 water pump, thermostat covers wanted, second hand?
Re: 582 water pump, thermostat covers wanted, second hand?
Ek het vir jou twee thermostat covers. Kontak my op 082 8041896. Ek sal baie bekommerd wees oor die res van daardie enjin. Anti freeze anti rust is n opsie!!
Seeing this I must add, do NOT use tap water with your coolant mix, only de-ionized water/distilled water. The chlorine in the tap water causes calcification , the white powdery residue.
As Boet said I would also have concerns over what the rest of the motor looks like inside the cooling system, also have the radiators cleaned.
Jean.
Jean.
Larry, I have two 90 deg elbows for you, one new, one slightly pre-owned, but very good condition. You can have both for R600
Boet 082 8041896
Boet 082 8041896
That is a good price Boet is offering the goods for there
J
J
Thanks, Guys.
Got the elbows, but still need the water pump housing!
Anybody know of a scrap engine anywhere??
Lm
Lm
Still Flying
