Hey All
I am looking for a set of Gears for a E-Box.
The Box i have has taken some damage and now i need a set of gears for it.
PM me or drop me a Whatsapp.
0&2 &9& 2I4 Five
E-Box Gears
E-Box Gears
- Leprachaun
Re: E-Box Gears
What ratio do you need , what wrong with the gears??
Re: E-Box Gears
Hi AlexLeprachaun wrote:What ratio do you need , what wrong with the gears??
I need the 4.00:1
The gearbox seized and damaged the small gear where it go's into the bearing. The rest is still ok and did not get damaged.
- Leprachaun
Re: E-Box Gears
Seized??? oil shortage or.... I have a Cbox that came in with similar problem? needles sto say had to cut bolts through casing to remove box , all us will check If I got 4:1
- Leprachaun
Re: E-Box Gears
Re: E-Box Gears
Hi Yea It ran without Oil after servicing.Leprachaun wrote:Seized??? oil shortage or.... I have a Cbox that came in with similar problem? needles sto say had to cut bolts through casing to remove box , all us will check If I got 4:1
The Main Gear is Good but the Center bearing seized and welded itself to the center shaft.
I was lucky in that as soon as the pilot heard there was a funky noise he shut it down so only damage was that Shaft and the bearing. I have stripped the box completely and will start getting all the bearings replaced and start to rebuild.
I am also looking for a starter to go underneath as well.
- Leprachaun
Re: E-Box Gears
Hi Gavin I got eboxes . c boxes as well as Starters that fit on the pull starter place genuine Rotax goodies I am busy cleaning my garage plenty spares I have ebox gears 4 . 1 Alex Leprachaun
