Brand New 12.5M Topless REVO Wing for sale
CraigL
Postby CraigL » Wed Jul 19, 2017 4:45 pm
This wing was bought and planned to be used on an experimental home built trike. My interests have moved elsewhere, and I no longer have the time or space to complete the project. The wing is as new, rigged once, and stored in it's original sleeve.
Value new is $9500, I'm willing to accept offers from R70 000. This is a high performance wing and requires a relatively powerful engine, Rotax 80HP or 100HP, so would not work for example on an Aquila with 503 or 582 engines. Would work on Delta Jet, Monsoon, Cobra 912, etc, etc.
Colours are green, blue and white.
Performance
* Cruise Speed: 65 – 100 mph (56 - 87 Knots)
* Max Speed: 115 mph (100 Knots)
* Stall Speed at Gross: 41 mph (36 Knots)
* Max TakeOff Weight: 1040 lbs (472.5 kg)
* Rate Of Climb (912ULS): 1000 ft/min (5 m/sec)
* Takeoff Distance to clear 50 foot obstacle (912ULS): 951 feet (290 meters)
* Landing Distance over 50 foot obstacle : 800 feet (244 meters)
* Descent Rate at 472.5 kg gross loading: 560 feet/min (2.845 m/sec) @ 58 mph (50 knots)
* Glide Ratio (Tested on Revo): 9.0:1
* Ultimate Strength: +6g, -3g
* Maneuverable Loading: +4g, -0g
* Wingspan: 27 feet (8.23 meters)
Wing can be bought separate, or together with the trike project complete with engine etc, etc, for R100 000. The project is 90% complete, has a CAA build number, and has successfully completed 4G static load tests to 1600kg's.
Contact Craig at 082 4590760 or craig@flyingfrontiers.com
CraigL
Re: Brand New 12.5M Topless REVO Wing for sale
Postby CraigL » Thu Aug 24, 2017 3:12 pm
Bump
