** Brand New ** Yaesu FTA-230 Airband Radios
Brand New Yaesu FTA-230 Airband Radios
Only R3900.00
While stocks last
http://capeavionics.yolasite.com/fta230.php
Phil - 0722111328
info@capeavionics.co.za
Only R3900.00
While stocks last
Phil - 0722111328
- Looking at the sky
Re: ** Brand New ** Yaesu FTA-230 Airband Radios
Hi
As discussed over the phone regarding the Airband radios.
are these radios ICASA approved with the approval certificate?
thanks
thanks
Where is the ICASA testing Centre?cjrectifier wrote:Hi
thanks
As far as i know they do not exist.
Only a type of TAX System
- Gerrit.Tromp84
- I hate bird strikes
It is quite serious to make sure radios are Icasa approved. And also have your approved handheld registered to your name. Not to long ago a friend of mine had his handheld confiscated because he did not have it registered to his name at icasa.
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
Info@gtflycom.co.za
0824000351
0121110085
Does it mean that all these private used ICASA approved radios ( Not Airband ) must be registered in your name as well?
- Gerrit.Tromp84
No that I can't answer. But airband is more serious and restricted. No unlicensed user may possess an airband radio without an licence. As I understand you will get locked up...
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
Info@gtflycom.co.za
0824000351
0121110085
By whom Gerrit ?Gerrit.Tromp84 wrote:had his handheld confiscated
Which ones, for example, are you referring to ?pierre wrote:all these private used ICASA approved radios ( Not Airband )
- Gerrit.Tromp84
By Icasa inspector and police. You have to register all airband radios you have to your name
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
Info@gtflycom.co.za
0824000351
0121110085
Did they come to his house ? How did they know ?Gerrit.Tromp84 wrote:By Icasa inspector and police.
- ForensicFlyer
- Solo cross country
I heard that a guy was parked at ORT, taking photographs of aircraft, using his Airband Radio to receive approach information.
The police pulled up next to him (because he was parked there, probably) and spoke to him a bit then arrested him.
The only time you are likely to get into trouble with an Airband Radio is if you have not done your radio license.
If a Radio is ICASA Approved (the importer, manufacturer or distributor gets approval) you are allowed to have/use it - as long as you are duly licensed.
So, no. As I understand the ICASA Act you do not need to register your radio - you just need to be licensed to have (own/operate) it.
Stan Bezuidenhout
- Gerrit.Tromp84
Hi Stan. Thank you for the info. It helps us a lot! There are so many tall tales out there one can get easily confused....
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
Info@gtflycom.co.za
0824000351
0121110085
