Selling composite propellers
meglin
Postby meglin » Mon Aug 10, 2015 8:23 pm
We offer carbon propellers for Rotax and other engines from 25 to 150 hp.
Available diameters are 1250, 1400, 1600, 1700, 1750, 1820, 1860 mm.
Blades type could be straight or saber.
Has a stainless steel protection.
More than 1000 hours of resource.
Photo and guidelines could be found here: http://propeller1.io.ua/
Please feel free to ask me any questions - consultations are free.
Good luck. Vladimir Meglinskiy
Best regards
Vladimir Meglinsky
My site: http://propeller.mozello.com/
Suesing
Re: Selling composite propellers
Postby Suesing » Thu Aug 13, 2015 9:21 am
What prop would you recommend for a Camit 125 HP engine?
Jabiru Instructor ( Grade B)
meglin
Postby meglin » Fri Aug 14, 2015 12:16 pm
Suesing wrote:What prop would you recommend for a Camit 125 HP engine?
We do not want to put the screws on its gearless motors.
While such precedents have been quite successful.
I recommend using a two-bladed wooden propeller.
What type of aircraft, flight mode and the necessary restrictions on the diameter of the propeller.
I will tell you the price and delivery time.
The propeller is made of beech wood, covered with fiberglass and protected by stainless steel.
Vladimir Meglinsky
http://propeller.simplesite.com/
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Fri Aug 14, 2015 12:41 pm
Some more photos:
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Fri Aug 14, 2015 5:06 pm
Two-bladed wooden (beech) propeller without protection is 200 €, with steel protection - 240 €. The diameter of 1540 mm. If a plane with a low speed flight, the diameter can be slightly increased, but at the same price increase.
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sat Aug 15, 2015 12:14 pm
Composite Propellers of this type are on the X-32 aircraft, the X-34, T-10, Sprint, Vis, A-20, A-22, Sigma, Aviatika, Chick, and other aircraft.
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sun Aug 23, 2015 12:37 pm
foto
Best regards
Vladimir Meglinsky
Suesing
Postby Suesing » Fri Aug 28, 2015 10:50 am
Thanks for the reply, it turns out your advice was 100 % sound. The one wooden prop looks nice,but luckily we do have our own South African wood prop master.All the best and success for your composite propellors.
meglin
Postby meglin » Wed Sep 16, 2015 5:36 pm
The new 6-bladed propeller diameter of 1420 mm. We are doing a new spinner with a diameter of 260 mm and length 290 mm.
Best regards
Vladimir Meglinsky
Gerrit.Tromp84
I hate bird strikes
I hate bird strikes
Postby Gerrit.Tromp84 » Thu Sep 24, 2015 9:48 pm
Hi. What is the cost for a 3 blade pusher for a rotax 503? The curved shaped ones? What is the weight of the complete prop including adaptor and nose cone?
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
meglin
Postby meglin » Sun Sep 27, 2015 11:46 am
Straight blades - 450, saber blades - 540 €. The mass of such a propeller about 4 kg, the mass of the propeller with the spinner and the extension sleeve - 5 kg.
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sun Oct 25, 2015 5:30 pm
Foto
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Wed Nov 11, 2015 1:23 pm
New spinners - carbon fiber, and the increased size:
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sat Nov 28, 2015 10:55 am
Just received a letter from Hungary. Owner draft measure up to his wooden propeller - 1250N. Then he set a 3-bladed propeller saber 1600 mm - thrust 1590N. Power - 50 hp
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sun Dec 27, 2015 10:46 am
American pilots confirmed the growth of three-bladed saber thrust propeller 1600 mm 25 kg with Rotax-503 engine.
Best regards
Vladimir Meglinsky
