O.D.co-ordinates
Post your intended route just in case
wingover
O.D.co-ordinates
Postby wingover » Fri May 03, 2013 1:39 pm
Hi Guys
Can someone please give me O.D. airfeild's co-ordinates aswell as can one land there?
Thanx
Loco
Re: O.D.co-ordinates
Postby Loco » Fri May 03, 2013 2:00 pm
Hi, you looking for ODI?
25°32'53.87"S
27°56'16.13"E
Anthony Hugo
Crosswinds
John.com
Postby John.com » Fri May 03, 2013 2:08 pm
wingover wrote:Hi Guys
Thanx
25°32'53.89"S 27°56'19.31"E 3870ft
Cautionary: OD has been converted into a drag racing strip and it is has been clearly demarcated with a "X", meaning "DO NOT LAND"!
With that said, there is enough room beyond the drag racing section for most light aircraft to put down in the event of a precautionary or emergency landing.
If you look closely at the image you can see the drag racing setup on the right hand (eastern) side.
Perhaps others with more knowledge of the airstrip could offer further guidance.
John.com
John Comley
Magaliesberg, South Africa
wingover
Postby wingover » Tue May 14, 2013 12:28 pm
Thanx for the info Gents. I will oad it in my GPS for a reference point when flying from my farm near Koedoeskop to Kroon. vhpy
Turbo
Postby Turbo » Wed Dec 25, 2013 10:16 pm
I sponsor this race track and have clearance to land here -- the person you need to contact is IVAN TOLLIE 076 564 4532
he will tell you if there is an event on, and they are only on Sundays ... every second sunday -- but call Ivan to confirm first.
wingover
Postby wingover » Mon Jan 27, 2014 10:28 am
Thanx Turbo
I only intend to land if it's a must nevertheless I will phone Ivan before I intend flying to or from Kroon
Turbo
Postby Turbo » Fri Feb 07, 2014 10:48 pm
Pleasure man , the runway is hardly used except for the racing which occurs every two weeks Sunday.
