pinedene route Baps to Haarties
Post your intended route just in case
zoobie
Postby zoobie » Thu Jan 03, 2013 8:57 am
hi guys
has anyone recently done the Bapsfontein-Pinedene/Wk-haarties route?
A few years ago I know they used to route us low level (5500) to WK, then to stay north of the shell ultracity but south of coinworld until crossing the freeway
Does this still apply?
is Waterkloof tower quite open/accommodating to us microlighters?
I intend routing from Baps to Haarties then to Brits and don't really feel like routing all the way around Wonderboom.
thanks for your assiatance.
safe flying.
"pilolts with big go**s fly taildraggers"
bobthebuilder
Re: pinedene route Baps to Haarties
Postby bobthebuilder » Sat Jan 05, 2013 10:38 pm
Zoobs ..... Take a look at this posting. The route changed slightly a while ago.
viewtopic.php?f=1&t=19285&p=187634&hili ... ne#p187634
When do you plan to go?
Byron Kirkland
Postby Tumbleweed » Sun Jan 06, 2013 7:35 am
Once in their space, report requesting Pinedene route. They will route you over the brickworks, request report overhead Pinedene station, route overhead the R something interchange, report the Rooihuis something watertowers in sight and you're in SRW.
From Pindene station, track a straight line to Aero 57 and you're fine.
On return if you state Babsfontein destination they will route you overhead Pinedene station and report Fly In estate in sight.
They're accomodating but sometimes I battle to understand the broad accent.
zoobie
Postby zoobie » Sun Jan 06, 2013 7:41 pm
thanks guys for all your feedback.
safe flying
ZS-NEL
Postby ZS-NEL » Tue Jan 29, 2013 11:25 am
A lot of times you will find Waterkloof unmanned. If manned, they WILL send you back if your transmission is bad.
Loco
Postby Loco » Tue Jan 29, 2013 12:55 pm
ZS-NEL wrote:A lot of times you will find Waterkloof unmanned. If manned, they WILL send you back if your transmission is bad.
Hi Marius, if they're unmanned are you allowed to route through via known Pinedene route or is that automatic not allowed?
Anthony Hugo
Crosswinds
Dish
Postby Dish » Tue Jan 29, 2013 6:28 pm
Its allowed, the towers closed, treat as unmanned, keep a sharp lookout and go through.... Make all relevant calls on relevant channels...
Bantam
DISH
ZU - DIF
John.com
Postby John.com » Tue Jan 29, 2013 7:05 pm
This might help if you use Google Earth . . . . Pinedene Route + Reporting Points!
Cheers, John.com
Pinedene Corridor.zip
(83.31 KiB) Downloaded 314 times
John Comley
Magaliesberg, South Africa
