GPS coordinates for VFR reporting points
Post your intended route just in case
Loco
Postby Loco » Thu Dec 27, 2012 10:49 am
Hi guys
Can you please help me out with the GPS coordinates for the VFR reporting points in:
http://www.cometaviationsupplies.co.za/ ... %20JHB.pdf
(The green triangles)
I'm specifically struggling to find the following:
- "Highway Junction"
- "Silver Ball"
- "Hartebeeshoek Tracking Station"
- "Rail/Road Bridge"
Many thanks
Ant
Anthony Hugo
Crosswinds
Loco
Re: GPS coordinates for VFR reporting points
Postby Loco » Thu Dec 27, 2012 10:52 am
Oh and if someone has the exact coords of the "Microwave Tower" north of "Gerotek Test Track" that would be great
Anthony Hugo
Crosswinds
D2O
Postby D2O » Thu Dec 27, 2012 11:04 am
anthonyhugo wrote:Oh and if someone has the exact coords of the "Microwave Tower" north of "Gerotek Test Track" that would be great
Are you referring to the SRW red and white radio mast reporting point at Harties?
Plane-less
Loco
Postby Loco » Thu Dec 27, 2012 11:06 am
Hi I guess so check on the map it's in orange "Microwave Tower" east of Harties
Anthony Hugo
Crosswinds
D2O
Postby D2O » Thu Dec 27, 2012 11:07 am
Use Google Earth. It's quite accurate at determining coordinates for known visual references :wink:
Plane-less
D2O
Postby D2O » Thu Dec 27, 2012 11:11 am
Yes, it is known as the "red and white radio mast". I regularly listen to Special Rules West frequency at home, and know the radio calls for the reference points pretty well.
HBV, Ernie Els Golf Estate, and Attridgeville Quarry are also reference points regularly called.
Plane-less
Loco
Postby Loco » Thu Dec 27, 2012 11:16 am
Thanks yeah I've been using Google Earth like crazy but struggling with some:
- "Silver Ball"
Btw what's "HBV" and is "Atteridgeville Quarry" = "Quarry Erasmia" on the SR map?
Anthony Hugo
Crosswinds
Loco
Postby Loco » Thu Dec 27, 2012 11:26 am
OK found the tower: 25°41'21.01"S 27°59'1.94"E
Anthony Hugo
Crosswinds
D2O
Postby D2O » Thu Dec 27, 2012 11:38 am
anthonyhugo wrote:Thanks yeah I've been using Google Earth like crazy but struggling with some:
- "Silver Ball"
HBV is a nav beacon which VFR pilots also use as a VRP. Atteridgeville Quarry is the same as indicated on the SR map.
- "Highway Junction" - checking
- "Silver Ball" - checking
- "Hartebeeshoek Tracking Station" 25⁰ 53' 23.25"S 27⁰ 41' 07.38"E
- "Rail/Road Bridge" 25⁰ 54' 35.00"S 28⁰ 31' 30.00 E
Plane-less
Loco
Postby Loco » Thu Dec 27, 2012 12:13 pm
Thanks! Got Silver Ball: 26°15'24.47"S 28° 4'53.82"E
Just missing:
- "Ga-Rankuwa Station" ---> 25°37'10.62"S 27°59'30.39"E
- "Rosslyn Station" ---> 25°38'15.96"S 28° 5'42.68"E
Anthony Hugo
Crosswinds
Postby Tribal Croc » Thu Dec 27, 2012 1:25 pm
anthonyhugo wrote:
Just missing:
Loco
Postby Loco » Thu Dec 27, 2012 1:35 pm
Tribal Croc wrote:
anthonyhugo wrote:
Just missing:
Thanks! (^^)
Anthony Hugo
Crosswinds
