- Grote
- Passed radio course
Grote se Safari mag nou ry
Oupa G , ek hoef nie meer te worry oor die file wat jy gesteel het nie , kyk Grote se site , ons kan nou sommer hier in die Kaap copies maak .
Grote has his papers, that means my papers are due soon. I could not risk it getting papers and the machine not finished. Today I flew again to George with the RedX, the plane was so busy and flew with all available crews this weekend. When I got back I went to the hangar and finished all the little things like installing the baffles and plenty cable ties. Torqued the prop and installed the newly painted spinner. It is now the correct yellow. The spinner was painted by the Loeriesfontein expert. I'm so glad that Boet can do this. Fibreglass and painting gives tears on the paint and also in my eyes. The spinners screws were installed with LocTite 243 the medium strength these screws tend to come loose.
I drained the petrol and will refuel with new motion lotion. The old fuel will go into the generator and other earth bound machines.
The engine started first shot and is ultra smooth. So the papers can come.
Enclosed some pics and I see the visits have passed the 130,000 mark.
- Wooden props and torque wrenches are good friends
- Prop Torque.jpg (45.25 KiB) Viewed 2650 times
- Spinner and LocTite
- Prop Torque1.jpg (48.09 KiB) Viewed 2650 times
- Landing light connected
- Prop Torque2.jpg (41.57 KiB) Viewed 2650 times
- Finished and ready to fly
- Finished.jpg (41.92 KiB) Viewed 2650 times
A bit of useless information.
We all know about the hydraulic lock that radial engines get when the bottom cylinder collects oil and also inverted engines and the importance to pull the prop through before starting. A friend of mine, the famous Trike Topless wing builder's daughter was caught recently driving in the floods in Gauteng . Her car ingested water with the end result visible on the photo. The hydraulic lock is the only explanation.
The connecting rod broke after 2000k's the other rod had the same potential. It is not often that you see this kind of deformation.
- This is not an optical solution or photoshopped
- Jenya1.jpg (62.08 KiB) Viewed 2594 times
Ek dink ons moet die papiere vier met 'n groot Bush Baby fly in!!
Ek sal graag die ander eienaars, Oupa G en vriende wil ontmoet en die ou bekendes weer wil sien.
Laat weet wat dink julle.
The higher, the faster, the safer.
Ek wag geduldig om die vlerke te toets is in beginsel vir al die BushBaby eienaars net tot voordeel.
This weekend just disappeared under me Flew Friday evening to Mosselbay saw some of the Cubby owners and builders, made sure that the prop blast of the Prat and Whitney did not over turn these nice little high wings. Saturday it was trike day and Sunday it was George with the RedX.
In my absence the Bosvark was washed and polished and I pulled her out of the hangar and did a good full power test. She has passed her wing loading test elsewhere I believe it is somewhere in Komatipoort, by you know who so now there should be no obstacles to get the paperwork. After all she was built exactly the same as the wings tested no difference. It is also nice to know that she is strong enough.
I thank all involved for the continued energy. I enclose a fotie with the new gear and spats. Looking forward to the final stretch of the paperwork.
- OTT ready.jpg (30.09 KiB) Viewed 2406 times
- RV4ker (RIP)
On my way to Upington today popped in at Loeriesfontein. I did some more fine tuning to the banana boy's EboXi. Made it to run leaner in cruise but it will still have to be tuned to absolutely match the prop. At the moment the EGT's run at 720C and that is very safe , but for economy and range it can still be tuned leaner to 780C. We prefer to run slightly rich. The bikes have a history of ultra lean mixtures and there have been holes in pistons on the road bikes. The mixtures that are run lean of peak have excess oxygen in the final burnt gases and that is after all an oxidizing flame , even if the temperatures are cooler then peak or slightly rich of peak. Slightly rich of peak is a reducing flame and not an oxidizing flame. About 100 F rich of peak is of course best power.
Caught a dust cloud midday at Loeriesfontein and then of course airborne . The foto is not out of focus but this aerie climbs so fast that it was to high to get a close up and it was so bumpy that Boet could not keep it still enough to pose for a picture.
- Dust on take-off
- FHY1.jpg (33.53 KiB) Viewed 2349 times
- caught in the air
- FHY.jpg (21.63 KiB) Viewed 2349 times
Today visited the RAF Gyro Mecca in Upington had a long chat to Eben and we decided not to mention CAA and we concentrated on other nice things like the new Zulu headset. I already had one and in full hope bought another one so that my passenger in the Bosvark will have equal comfort. I hope this can happen soon. There is a saying "Beware when a patient man gets cross"
I'm almost there.
I'm almost there.
Ja OupaG hulle se mos op Afrikaans " Die makste perde skop die hardste!! "
Jean
Jean
- clive layland
- Pre flight checks done
Nice finally meeting you in Mossel Bay Oupa G.
Greetings, Cubby Squadron!!
Clive thanks for the foties. The PC12 like a Cub is a magnificent machine to fly and I feel very fortunate at my age to be healthy and to fly the full spectrum of aircraft. I have a deep respect for everything that flies. Today I flew my Trike to Cape Town International I know the airport well as well as the controllers. They let me in without a transponder and the help was a phone call away. I was the smallest so I was last in the queue I sat on right hand downwind for 01 circling and having a birds eye view circling there were Boeing 777's 737's, big Airbus's , regional jets etc etc and eventually the mighty trike landed on this massive runway crosswind no problem with that width you can cope with any wind. I taxied in went to ground control and parked in the hangar amongst a Bentley, an Aston Martin, a magnificent wooden boat and a Citation Jet. At least I can say of the aircraft in the hangar I like my trike best . I have flown Citations for 1800hrs but the trike is more fun.
Enclosed the proof in foto format
- The mighty BMW trike
- DCM.jpg (47.29 KiB) Viewed 2091 times
My wife and i were at the Mosselbay fly-in and had the good fortune to see the Pilatus PC12 come in to land , as the PC12 landed i said to my wife " I take you a bet that is Oom Frans at the controls" and it was! So here is some 1st hand proof that OupaG does do his bit for humanity, well done OupaG, it is a privelege to know you!
Regards Jean
Regards Jean
Thanks JeanTree it was a quick call no uniforms I was scared that the weather was going to come in the dew point and the temp were only 1 degree apart and that coast can have its weather surprises, the cloud layer can be seen on the fotie. Low cloud and night are not good friends without an ILS. Hope you had a good Cubby weekend.
Went back today to Cape Town International and picked up the trike and flew back to Grootfontein no waiting immediate take off from R19 and left out to our field. I was snapped yesterday coming in, and I took a fotie while taxiing . Only then one realizes how small we really are. With the Bosvark I'm waiting in anticipation.
Thats all for tonight.
- Small bird big airport
- CT int2.jpg (42.77 KiB) Viewed 1996 times
- Just look at this immense space Keeping the nose wheel on the line so that my wheels won't go of the tarmac
- CT int1.jpg (35.42 KiB) Viewed 1996 times
Users browsing this forum: No registered users and 37 guests
