Deons CH 750 Project (Was Conrads)
Re: Conrads CH 750 Project
Cross-wind I also use these same connectors they keep out moisture and are really high quality,
good luck with the build.
- cross_wind
- Got my wings at last
This weeks update 14 Jun...
- Busy finishing off the wing but now have to install fuel tank, fuel flow sender and block off stupid extra hole in the fuel tank (still not sure how to do that) Once I have the fuel tank installed, I can close up and start wing # 2. I will strap the nose skin tonight and begin final drilling on the top skin (just remembered that I have to assemble my daughters pram tonight.......)
- Snug as a bug
- 20110614 8.JPG (97.35 KiB) Viewed 8905 times
- 20110614 2.JPG (91.38 KiB) Viewed 8905 times
- Cork ensures no rubbing or friction spots
- 20110614 4.JPG (94.99 KiB) Viewed 8905 times
- Epoxied cable tie mounts to the spar
- 20110614 5.JPG (92.25 KiB) Viewed 8905 times
Cross_Wind
Challenger II LS ZU-FCP
Conrad are you sure that you are 17.5% complete not 17% complete?
- cross_wind
Probably more like 17.70 % complete. What else do you expect from a Project Manager?Scotsman wrote:Conrad are you sure that you are 17.5% complete not 17% complete?
Cross_Wind
- cross_wind
Busy with the copilot wing skin - will upload photos when my pc returns from IBM (mother board fried).
Cross_Wind
Amazing to see her take shape!!
Len M
The knack [to flying] lies in learning how to throw yourself at the ground and miss.
Hi Conrad
Is that Hard drive replaced yet would like to see progress/photos
Visited Bundu aviation yesterday they have employed an extra pair of hands gentleman by the name Gordon Keith.
Progress with the wings at last ,Q is finished with the electrics,so according to Phillip he seems to think give are take 2 weeks and if the
CAA Paper work is in order they expect to do first flight test.Really looking GOOD
Big Mac
Big Mac
- cross_wind
PC's working again - pity I am not. I have been fighting this terrible flu for the past two weeks (still not over it).
I have finished bending both wing skins and have drilled all holes to final size. Now to strip, debur and re-install. I am not rushing at the moment as I need to buy my nav lights before I can finish and its flipping cold at night in my garage!!!!!
Cross_Wind
- cross_wind
Wing skin finished
Cross_Wind
- cross_wind
Still need to figure out if I should drill the root skins to size.
Cross_Wind
- Duck Rogers
Drill them (root skins) to size but don't trim. You do the trimming once the wing is on the plane because it's where it touches the roof of the cabin that matters. Once the wing is fitted you'll see nicely where to trim.
- cross_wind
Thanks for that - makes sense. I now need to get myself a pair of crimp pliers before I can continue.
- crimp.jpg (4.46 KiB) Viewed 8589 times
Cross_Wind
- Duck Rogers
Make one. Dead easy if you can weld.. Took me about 20 minutes to turn a R40 scrappy pawn shop pliers into a R300 crimp plierscross_wind wrote: I now need to get myself a pair of crimp pliers before I can continue.
Looking good Keep going
Conrad I have a crimping thing that came in the kit that you can borrow if you want. I am in the west rand if that helps?
Users browsing this forum: No registered users and 54 guests
