Tailspin's VP-1 Project & Sun Bird Deviation
Re: Tailspin's VP-1 Project
Postby Tailspin » Wed Jun 18, 2008 2:35 pm
Hi All
Just fitting the 6X600 wheels ## with the brakes and trying to get the CAA thing sorted. s074 s074
grostek
Postby grostek » Thu Aug 21, 2008 3:38 am
Hi Gavin,
How is the VP coming along, and have you got your ATF for proving flights yet?
Kind regards,
Gunter Rostek.
Postby Tailspin » Fri Aug 22, 2008 8:13 am
Nope :evil:
CAA want me to do a stress test on the wings. Looking for some space to setup the bird get her rigged and then i can make a jig to invert her and start with the tests.
LarryMcG
Postby LarryMcG » Fri Aug 22, 2008 8:56 am
Hi Gavin
Was told the same thing, but submiited an applcation for exemption - cost R1080 but was given an exemption from stress testing.
Some say that it is an option, that I shouldnt have paid the bucks, and that we can choose to test fly, not stress test?
Have you tried that?
Give me a shout if I can help with paper trail!
Larry
Still Flying
Postby Tailspin » Fri Aug 22, 2008 9:34 am
Larry
I will give you a shout soon.
Starting a new company at the moment so CAA is on back burner till end next month then will get back into the swing of things.
grostek
Postby grostek » Fri Aug 22, 2008 9:42 am
Hi Gavin,
Sorry to hear about your extra trouble.
A small tip (Maybe)
When the Cubby guys tested their wings under CAA supervision I was there as sand sackfiller at the scale and loader onto the wing, in general just helping out.
Anyway as only the wing was tested, they used the Collumn of the building as the jig.
They welded a cross piece to the column at hip height and hihger up the column a bracket where the lift struts could be bolted.
The wing was mounted upside down to the cross piece on the column the lift struts bolted to the fitting higher up and proof loading commenced.
The point of all of this was so that a fuselage need not be mounted upside down in cradles where the possibillity of damage to the aircraft during turning over and fitting into cradles was a real certainty.
You may want to discuss this option with CAA as you will need a lot less space and just a sturdy (say 203mm x 203 mm H Beam) and 2 smaller cross pieces (one for the wing and the other lower down near the floor for the lift struts) that can be welded to this Column to do this test.
The fitting for the lift struts is below the wing on the column now because the VP struts sit on top of the wing and the wing is inverted so that sacks can be placed on it.
I have attached 2 sketches to show the method.
I hope this helps you and that you will be able to use this method.
Kind regards,
Gunter
VP Wing test Layout1.pdf
(3.33 KiB) Downloaded 280 times
VP wing test Layout 2.pdf
(3.61 KiB) Downloaded 354 times
Postby Tailspin » Fri Aug 22, 2008 9:58 am
Thanks Gunter.
I will take a look see. I know the wing is good till 6G's but i will only be testing her to +4.
Watch this space.
Guest
Postby Guest » Fri Aug 22, 2008 10:49 am
Gavin it's because of the wooden structure that worries the CAA. I went through the same problem with the L-18 even though an aero engineer checked the whole design!
The metal and tupperware aeries can be mathimaticaly proven (even if all the fastners are not installed correctly, or rivets not drivven to spec making the thing weak) wood is just not that eazy , and I was told by a CAA official that the glue joints could be a problem, hence the test :roll:
You need to only test 1 wing and attach points for them.take alot of photos from every angle at 25%,50%,75% and full load and check full movement on aileron.
Even though the Part 24 clearly states that a load test is required only for a prototype or first of production plane (wich yours and the L-18 isn't) CAA still want's it and you will not get away without it!
Good luck
Theuns
Ps. I have pix of my load test ,i will e-mail them to you if you want.
Willie
Postby Willie » Fri Aug 22, 2008 11:21 am
Guest wrote: Ps. I have pix of my load test ,i will e-mail them to you if you want.
Please mail them here. :wink:
ZS-APM C182
ZS-UJC Hatz
ZS-VTV Thunderbird MK4
ZU-EJD Thorp T-18
ZS-PPT Tecnam Sierra
ZS-UGS VP2
ZS-UNC KR2
ZS-DMW Tripacer Crashed 1985
Guest
Postby Guest » Fri Aug 22, 2008 9:37 pm
I can if someone tells me how to upload the pix to a reply?
Cant see the "attach" function here as on AVCOM :oops:
Theuns
Postby Tailspin » Wed Aug 27, 2008 9:07 am
Hi Theuns
Mail the pic's to me and i will put them up.
eogavin @ unisa . ac . za
Guest
Postby Guest » Thu Aug 28, 2008 7:23 pm
Will do
Theuns
I hate bird strikes
I hate bird strikes
Postby Frequent Flyer » Fri Dec 05, 2008 10:36 am
hi tailspin, i'm looking for plans for a fly-aby or a VP, where can i get a set?
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
Postby Tailspin » Tue Dec 09, 2008 8:49 am
You can ask me very nicely or you can go to
http://www.volksplane.com
swiftprop
Postby swiftprop » Tue Dec 09, 2008 9:19 am
Hi Gavin
Any more progress on your project?
Flying regards
Andre
