Radial Explorer Project - Da Animal
grostek
Postby grostek » Thu Oct 25, 2007 10:21 pm
Hi Boet,
No to showing how not to do it or
No to Morphs Pics and build description.
Am slightly confused.
Kind regards
Gunter Rostek.
Postby Boet » Thu Oct 25, 2007 10:41 pm
NO :!: I did not take pics. Would not have been up to scratch. :oops:
The easiest way to confuse him: Put two shovels up against the wall, then tell him to take his pick......
grostek
Postby grostek » Fri Oct 26, 2007 4:59 am
Thanks Boet,
Ja ek slaap want jy vertel ons al n week lank jou kamera het n groot hammer nodig :!:
Jammer as wat ek geskryf het onbeskof geklink het :oops:
Groete
Gunter Rostek
Postby Boet » Fri Oct 26, 2007 7:31 pm
:D
Postby RV4ker (RIP) » Sat Oct 27, 2007 11:01 am
Boet wrote:NO :!: I did not take pics. Would not have been up to scratch. :oops:
Hu? :shock: :shock: :shock:
Postby Boet » Sat Oct 27, 2007 7:33 pm
We will discuss that on the side...... personal. :D :D :D RTFM. Petol tanks installed, ( PROPERLY this time. :roll: ) and we are giving the glue time to set properly over the weekend. :D :D :D :D :D
Postby RV4ker (RIP) » Sat Oct 27, 2007 7:46 pm
Was nie ek nie.... 8)
Postby Boet » Sat Oct 27, 2007 10:01 pm
Duidelik iemand wat nie kan lees nie...... :lol: :lol: :lol: :lol: :lol: Toe maar, ek kon darem die droogmaak reverse engineer. :wink:
Postby Boet » Wed Oct 31, 2007 9:37 pm
Today all the sheet metal work around the cabin was completed. The new leading edge cuffs arrived yesterday, and the tyres today. I started swotting up about the engine. Seems simple enough. I am getting a new camera for my next birthday......soon :!: :!: :D :D :D :D
RV Sometime
Postby RV Sometime » Mon Nov 12, 2007 4:03 am
Yup, I obviously made more mistakes than I knew I had.
One that was not even mentioned was to fit the leading edges on the wings prior to the fitment of the wings to the fuselage together with the jury struts. I was going to simply make a window where I removed the fiberglass in the jury strut area.
I did find the tanks difficult to install but was too scared to remove too much material in case I opened a void. I am glad this has been sorted.
Where I am totally confused is where I went wrong with the I beams. I did not round off by hand, I jigged it into my lathe & was quite proud of the results. This worries me big time because of our collective asses in a sling in such an important area.
Boet, can you please give details of the buggerups so that other builders don't make the same mistakes I made :oops: :oops: :oops:
Has the wing got the correct washout & are they straight. I'm kinda worried now.
Congrats are in order, she is really looking fantastic. :D :D :D :D :D
Postby Boet » Mon Nov 12, 2007 5:43 am
:D The mistakes you made? You did not RTFM. NO varnish :!: The stiffeners not upright. Stiffeners not in right position, and not screwed in correctly as per the manual. Fortunately I could rectify. The glasfibre leading edges I had to remove. They looked bloody awfull. I am re-doing the whole damn lot. Unfortunately could not re-use the originals. We fitted the wings to the fus, and measured everything VERY accurately, you can sleep easy, she will fly straight as an arrow. The flapperons have also been fitted. All controlls working :D :!: I will post some phodies this week.
FAWGie
Postby FAWGie » Mon Nov 12, 2007 8:26 am
:lol:
RV Sometime
Postby RV Sometime » Mon Nov 12, 2007 8:28 am
Jy weet hoe om "n ou te laat skaam voel, Boetie :oops: :oops: :oops: :oops: :oops:
Thanks for the feedback. :D :D :D :D :D
FAWGie
Postby FAWGie » Mon Nov 12, 2007 8:34 am
RV Sometime wrote:Jy weet hoe om "n ou te laat skaam voel, Boetie :oops: :oops: :oops: :oops: :oops:
yes, but does he have a way with woman..... :wink:
Barnstormer
Postby Barnstormer » Mon Nov 12, 2007 12:24 pm
When is your birthday so we can see some photos again? 8)
Planeless...
