Postby Oddball » Mon Oct 29, 2007 3:04 pm
Hello Barnstormer, and others...
As mentioned before, you do not need to be a member of any organisation in order to have an AP sign your annual inspection off. This used to be the case but has not been for a while now. There is some argument as to whether this should again be the case in terms of the new regulations that will be promulgated in 2008. As far as I know this clause has been removed- I will ask Mike (Blyth) about it and get back to you.
But right now it is not a legal requirement. The MISASA committee generally feels that an AP should encourage a pilot to join MISASA, but not insist on it.
MISASA's constitution has been changed to now include light sport aircraft, which is a new category of aircraft that will come into effect next year (similar to the American LSA category). The name MISASA will stay however (so far there are no suggestions to change this).
The issue of money is somewhat of an interesting point; we do need to gather some sort of collective income from members, but what to do with it? Unless one gets a lot of members (lots of members * reasonable subs, or, few members * high subs) you do not have sufficient money to employ someone to look after the members interests- and it is a full time job for sure. Mike spends a LOT of time working on MISASA matters, and that for free. Sure, he is in the aviation business and may stand to benefit, but unless you can justify the time in this manner you simply cannot spend the kind of time that Mike does spend.
So what to do? If we make joining a body complusory everyone squeals because they are forced to join; if we don't then there's squealing because MISASA are not doing enough to protect the collective interest, even though only a small part of that collective now contribute.
It's either time or money, like most things in life. Either members donate time to look at matters such as the new regs, or they donate money to employ someone to do it on thier behalf. The cry is often, "what is MISASA doing for us." The answer is simple; YOU are MISASA, what are YOU doing? ...
Back to the Aeroclub and its sub-sections. The Aeroclub represents all of general aviation, as an umberella organisation. Each section, such as MISASA, or the EAA, pays dues to the Aeroclub, who then employ someone (Neil De Lange in this case) whose job it is to speak to the CAA on behalf of GA pilots.
So you can join EAA instead of MISASA, or any other subsection. However, EAA, quite rightly, spend thier efforts to look at and fight about things like aircraft registration, or rules pertaining to aircraft building.
I am a member of both EAA and MISASA, since I fly microlights and also build. I only need to be a member of the Aeroclub once.
The issue of whether one should have to join an ascociation is thorny; Barnstormer, and others, seem to agree that it is a good thing, and no one who flies is really going to miss the R400-500 per annum fee to join MISASA and the Aeroclub. But there have been objections to such a move. The employment of a permanent representative is also thorny but I think that ultimately that is exactly what is needed.
Perhaps we need a poll on this?
Jay Hyde
MISASA PRO
