RAF gyrocopter accidents
Re: RAF gyrocopter accidents
Hi Michiel
Like I said I will inform you of the PRA membership.
Direct Quote form Duane Hunn ( Gyro Pilot and CFI with 8000+ hours on Gyro 's and he prefers to fly the RAF 2000)
"Hi All. The pra is still going but just barely. We have about 1400 members depending on what day it is. It gos up a little then down a little and up.
It use to be over 5000. That was a few years back. All this in fighting that has been on the rotor forum has not been good for the industry. A new idea is needed to brake it up. I have a few but more input is need. cya for now. Keep the wind in your face. Duane"
Hi Saraf, according to the secretary herself there are more than 2000 members currently,so Mr Hunn has got it wrong...
This is what C.Beaty said regarding Duane under the topic 'IS THIS THE REASON WHY RAF WENT BELLY UP?' in the Rotary Wing Forum on 10-26-2007:
'The thought has just occured to me that RAFwent belly up not so much because of the intransigence of Don and Pete who after all ,were simply operating a manufacturing\sales organisation that could just as well have been making tennis shoes,but from receiving erroneous technical advice.
After Dan Hasseloh was killed in a gyro crash,there was no in-house knowledge of gyros or a single individual on the payroll that could even fly one.RAF had to look outside the company for technical guidance.
It seems to me that Don chose the wrong source in listening to Duane Hunn and fellow travelers and did so merely because their arguments seemed to mesh with the views of their fallen leader.'
And then by GyroRon: 'I think that it was said that both Duane Hunn and Jim Logan are now telling their students that a true Horizontal stabilizer is a good thing to add to their ships'
Greetings, Giel
Greetings, Giel
Hi Giel
Weereens het jy aan almal op die forum bewys hoe oningelig JY en almal op die Rotary Forum werlik is oor die RAF.
Weet jy wat , jy vlieg nie n gyro nie , so hoekom het jy so baie te se oor hulle, jy het veranderinge gemaak aan die RAF , en aan die ELA soos jy gese het in n ander post. Nou vlieg jy n Jabru , het jy die ook al verander???
Giel ek het nie die tyd en energie om met iemand soos jy te redekabel oor iet wat jy niks van weet nie.
Sterkte met jou vlieg loopbaan.
Eben Mocke Jnr
P.S - Ek sal jou Duane hunne se Sel nommer gee, dan gesels jy biejtie met hom oor Horizontals dan hoor jy wat hy 2 dae terug vir my gese het wat hy dink daarvan van n Horizontal op Die RAF. As hy aan almal gese het hulle moet een opsit, hoekom het hy of Jim logan , of Dofin Fritts nog nie een opgesit nie. Tussen die 3 van hulle het hulle meer as 13 000H op die RAF.
Ek stel voor jy gaan gesels met die manne op avcom oor Jabi's en vaste vlerke. Ek dink dit is meer jou veld.
Eben Mocke Jnr
Hi Eben,
Dankie, ek beskou dit as n groot eer en vooreg om gelyk gestel te word aan die duisende ouens op die Rotary Wing Forum en PRA,maar ek dink meeste is my baie ver voor.
Ja, ek verander aan die Jabi;gaan kyk op die forum by avcom vir Jabis.Ek het verlede week in samewerking met die fabriek op George begin om vortex generators te installeer en hulle is heel in hul skik met die resultate sover.Nogal interesant,n gyro loods vra my verlede week of dit sal werk op n gyro se lemme!
Groete Giel
Groete Giel
Saraf,hoe vorder die planne vir n besoek aan Wagtail? groete.
Ek het persoonlik in 'n RAF gevlieg met en sonder 'n horisontale
stabiliseerder.
Sonder die stab is die RAF in die "pitch plane" onstabiel en jy moet hom die heel tyd vlieg
soos met 'n Robbie R22.
Met die stab is hy baie meer stabiel en kan jy hom "hands off vlieg"
Ek persoonlik sal nie graag in 'n RAF sonder 'n stab wil wees in turbulente toestande nie.
Dit is net snaaks dat al die ander vervaardigers en al die ander gyro pilots
verkeerd is en net die RAF manne reg is.
stabiliseerder.
Kerneels, you need to accept the aircraft as a package and you need to be taught how to fly it.
After 11 hours or instruction I flew two complete circuits on a 5km long runway without touching the stick! - rudder and power only. Now that is hard to do in a pitch unstabble aircraft. I then flew the aircraft on a 6 hour cross country stopping only for fuel and the stick input was second nature and about the same input as is normally required from the steering wheel of my car. I flew in 20 knot winds from Upington to Saldanha through the middle of the day over the escarpment and in rough turbulence. I had no problem controlling the aircraft and I am a student in her. The manufacturers are not swimming upstream, they have an alternative design which is the result of 40 years of research and development. I admire and commend free thinking.
I notice that those that have been trained in the RAF fly a lot without spending time trying to convince everyone that theirs is the better aircraft - (notice their lack of comment on the forum). They are happy and safe - something we should all strive for. Do your research and that means flying with competent manufacturer rated instructors in the various aircraft. Get different opinions, choose your Gyro and join the gyro community.
Seems to me that those that have a lot to say about the RAF are not informed and have not taken the time to learn how to fly it. I can assure you that within 10 to 15 hours of training all your concerns will be answered to your satisfaction - unfortunately that costs time and effort. In short I found the RAF to be the most remarkable aircraft I have flown. I did 2 and a half years of research which included flying in the Sycamore and the Ela with instructors.
The so called experts told me that the Sycamore was too heavy and under powered, but I persisted and took the test flight anyway. What a surprise when the aircraft lept into the air after 70 metres with a 800+ ft per minute climb. The instructor allowed me to take the stick and do left and right turns - I found it easy to fly. The same went for the Ela except there were other supposed problems which never materialised. I chose the RAF at the end of the day, but remain a gyro enthusiast. It was the best considered choice for me.
The RAF manufacturers have never denied that substantial training is required to fly their gyro, in fact they insist on it. It is not a conversion, it is training from the ground up.
Send me a private message if you want me to elaborate on some other issues that I uncovered during my research, but unfounded statements should be kept to yourself unless you are prepared to state your credentials and the rationale of how you came to understand that the aircraft is pitch unstable. What you probably experienced was PIO (pilot induced ossilation) and after propper training you will understand it.
What prompted this post? Did something happen that you think we could all learn from? Where did you fly a RAF with a HS?
It is not the arrow - it is the indian!
Unfounded statements ? I flew it myself boet. PIO's, no definitely not.flying-i wrote:
Send me a private message if you want me to elaborate on some other issues that I uncovered during my research, but unfounded statements should be kept to yourself unless you are prepared to state your credentials and the rationale of how you came to understand that the aircraft is pitch unstable. !
How do an experienced instructor in the USA with 1000 ths of hours on the RAF kill himself in a bunt over
in turbulent conditions ?????????????
Did you buy the RAF because it was the cheapest ??
I am not getting involved in this argument, I love all gyro's and the machine the Mocke's are selling. I in any case don't know enough of the RAF to comment or know of the changes (if any) they made since they took over manufacturing.
Flying-i, I just think you can't comment on the difference of a horizontal stabilizer if you haven't flown one with it. Just scary that you talk about PIO in the RAF and one need training to understand it for the RAF, where in all other modern gyros this is almost unheard of these days and only associated with old design gyro's.
Found an interesting link below, just as food for thought. This is an old article and like i said, don't know what changes and changes by RAF SA have been made since.
http://home.att.net/~raf2000owners/horiz_stab.htm
www.altairaviation.co.za
This is the articles
Horizontal Stabilizer Discussion from RotorCraft Conference
Back To RAF2000 Owners Home
Summary: Following is just a snippet of the many-many horizontal stabilizer discussions that appeared on the old RotorCraft Conference. The newer http://www.rotaryforum.com forum holds many similar opinions.
Issue: The consensus is that the RAF 2000 should have a horizontal stabilizer.
Links to Horizontal Stabilizer manufacturers:
Anyone have current information to put here?
Date: July 03, 2002 09:10 AM
Author: Larry Martin (earthloc@worldnet.att.net)
Subject: RAF Stabs
It has come to my attention that RAF is working real hard to convince the FAA that the RAF machine doesn't need a stab and that in fact a stab is a safety impairment to their machine.
Here is the exact quote from the RAF manual, product notice no. 30 dated June 2000.
"Horizontal Stabilizer: The RAF 2000 Gyroplane was tested by the factory with a Horizontal Stabilizer. It was found to have some adverse flight characteristics evident during the testing and there was a consequential crash of the test aircraft in 1996" and they go on to say do it at your own risk and so on.
...TEXT DELETED...
Bad Stab Page
"Don't squat with your spurs on!"
Date: January 21, 2001 12:24 PM
Author: J P McNear (rotorforce1@aol.com)
Subject: Horizontal Stablizer
I've installed a horizontal stabilizer on my RAF-2000 and am amazed at the difference it's made. The pilot workload is dramatically reduced and even though my stab has no dihedral, the landing flare is fine. It does NOT try to fly into the ground. I can trim it out and it flies with very little control input in all kinds of Florida weather.
I assembled the kit in 1996. It went together easily and quickly and the quality of the parts was first rate. In my dealings with RAF, Peter, Don, Linda, Maryanne and everyone else was always professional, courteous, helpful and responded promptly to my requests. I also thought Dan was a very good pilot.
I flew the gyro for 450 hours and thought it was a fine cross country machine. I grew up around machinery and like a lot of people in Southwest Florida, built and drove race cars, air boats, gigged frogs, hunted coons and raised hunting dogs. I think because of this (machinery, not coons, dogs or frogs), I haven't experienced the mechanical problems some people have complained about. The rod end bearings supporting my alternator haven't broken because I set them up so there is no sideways or bending load. I haven't had redrive belts chew themselves up. And they don't if properly aligned and tensioned.
Early on, I had the lower drive sprocket bored and sleeved at a local machine shop for a reasonable cost, not the exorbitant price I've seen quoted on the Conference. I also installed a double bearing rotorhead from Ernie at RFD.
I've installed most of the factory upgrades. The new factory ignition, on completely different circuits as are the fuel pumps, hasn't missed a beat after 300 hours. The new prerotator clutch works very well. I got the new untwisted, tip weighted blades at 475 hours and feel they fly better. I intend next to install fuel injection and the new seat tanks.
So, after 450 hours, I reluctantly bought a horizontal stab, thinking it wouldn't make all that much difference. Was I ever wrong!
I purchased the stab from Don Parham of RFI for $375 plus freight. It has 18" tip plates and no dihedral. I mounted it behind and below the vertical tail by sawing a strip out of a length of 2 x 2 aluminum tube to reduce the dimensions to 1.75 x 2, welding it back together so it would telescope inside the keel tube. The stab mounts on this tube. This method of installation gives a longer moment arm and makes it easier on the legs when wrestling it around on the ground. The tail wheel has to be offset slightly to the side.
This stab has made what I thought was a good cross country machine into a great cross country machine. The tip plates cure 95% the yaw problems when the doors are installed. I have over 500 hours and just love the way it now flies. There is no way I'd go back to flying without a stab.
Date: July 06, 2002 02:24 AM
Author: Paul Bruty (paulbruty@lexicon.net)
Subject: The problem with........
......a lot of people being trained in unstable aircraft, is that they think that all gyros behave that way.
I was one of these people. Following is a story that I wrote in June of 2000.
Well, after 12 months of testing with my RAF 2000, a variety of different size, shapes and dihedral angles of horizontal stabilisers, I now put pen to paper. I have tested with all sorts of loads and in ALL sorts of conditions on a number of machines and rotor systems. I have found that a relatively small flat plate placed behind the engine on a gyroplane is not necessarily an "effective" horizontal stabiliser. The higher that the thrust line is above the vertical C of G the more important the stab is. A lot of machines now have high thrust lines due to the reduction units and large diameter propellers that we now use. It all started in 1982 when I bought a partly built Bensen style airframe that already had a stab under the fin and rudder as well as the rock guard. My dad and I fitted a direct drive 1905cc VW with a 53" prop and 23' Rotor Hawk blades (resulting in a low thrust line) and got flying. (We had flown Gyrogliders in 1962 and my dad had done about 70 hrs with a Mac with the usual attacks). I did 350 hours in this machine and did not know what Porpoising or Power Push Over(PIO and PPO) felt like. In 1989 I started training in a side-by-side Air Command with the longer mast, raised Rotax 532 driving a 68" 3 bladed prop and 25' blades.
My first student was a friend who was flying fixed wingers and due to the cost he thought he would try gyro flying with me. We started by flying the length of the runway and then taxi back and do it again. At that point I was not comfortable flying dual around the circuit with a single ignition 2 stroke and marginal rotors. My friend kept over controlling and porpoising. We packed up at last light and went home. I got to thinking about a pic I had seen of an Air Command with a cabin and their h/stab, so that night I made a temporary one, from memory out of ¼" ply and steel straps. The next evening we go out again and my friend is doing so much better. During a break for fuel I took the stab off, and low and behold he is almost back to the way he was the evening before. The next evening we went out again with the stab and he was progressing well. He soloed some months later. I never trained without a stab again. I believed that problems the students would have learning were just due to the inherently unstable flying machine, that we called a gyroplane!!!
I have had many an argument with experienced gyro pilots that declare that they do not need one. I say to them, experienced gyro pilots don't, they have the necessary skill to control the gyro so as to avoid danger. A stab is most useful for students, and to the low time pilot caught in rough weather. "Effective" h/stabs become more important as the thrust line gets higher. This has become more prevalent with the arrival of the reduction drives and associated larger diameter propellers. These designs place the thrust line above the vertical C of G, which results in the propeller rolling the machine forward when a gust unloads some of the rotor drag. One option is to raise the cabin or seating area, which makes the gyro difficult to get in and out of, particularly as we become older.
The other option is to fit an effective horizontal stabiliser. This is the path that I have taken. Some people are quoting wing commander Wallis, and others, who says that h/stabs are not necessary. They weren't in the days when all the machines had direct drive with short props, thus keeping the vertical C of G in the correct place. In 1990, when I was National president of our Australian Sport Rotorcraft Assn. (ASRA controls gyro flying on behalf of our government), we made effective h/stabs mandatory and implemented a ratio between rotor head and stick movement to keep the sensitivity down. I did over 1600 hours training in my Air Command during the next 8 years. A couple of years ago my chest (I was then 49 y/o) decided that it had had enough of the cold air and I looked for a machine that would allow me to go places and train in comfort. Having a look around the world, the only machine that really met my criteria and had sufficient machines operating safely was the RAF 2000. The only thing I was disappointed in was the fact that it did not have an h/stab as I had proven the h/stab to be essential, particularly for students and low time pilots. It was explained to me that it did actually have one by way of an arrangement with a rubber mast bushing and control linkage set up. I was told that this did the same job. I believed what I was told and became a rep for the RAF factory.
This about the time that I found Norms wonderful forum and went toe to toe with the anti RAFers. I am sure that a lot of you will remember that time.
When I got flying the RAF I was very happy with it, but found that the mast set up did a good job of lowering the nose when it rose but would not lift the nose when it went down due to rough air. This meant that the student only had ½ the workload to start with until they became more proficient. My Air Command (or any high thrust line gyro) even with the stab (which I now know was too small) required quite a high student workload during the early hours. We went to 1999 Bensen days and met some great people from the factory as well as locally. I flew in 3 different RAF's and found that they all behaved the same as mine. It was comforting to know that our machine flew normally compared to other RAF's.
A month later my wife and I were in New Zealand on holiday and I had heard that Rob Sanders, who I had trained in my Air Command a few years earlier was a RAF rep, and that he had experimented with h/stabs on the RAF. We went down to see Rob and other pilots I had trained to catch up with them and to check out the stab situation. Rob told me how they had developed the stab over a period of time because of the extremely rough air over there between the mountains, and flying could be very uncomfortable and almost dangerous. The conditions were moderately rough and Rob said that it was not rough enough to do the stab justice. Being a very untrusting soul I said that I would love to try it out. Off we went and Rob trimmed the machine to 60 mph and handed over to me. I naturally went easy with it but I was doing a lot more than I needed to. I eventually did what Rob said and let it have its head and I could not believe what was happening, a gyro flying itself in quite rough air. (Rob did not think it very rough) When we got to a 1000' Rob took over and did a zero airspeed and engine idling vertical descent down to 500' without any dramas at all. I then took control and began climbing towards a 900'mountain to see if we could get some rougher air on the lee side. As we were getting closer and could almost see the whites of the eyes of the tourists I thought that Rob was going close to the mountain when I realised that I was supposed to be doing the flying and turned away. I had been sitting there like I was instructing, just resting my hand on the stick ready to take over if needed. Rob of course was doing the same only he was thinking I was flying. The machine had climbed 400' through rough lee side air on its own. I was amazed. I then eased the stick forward until we hit 85 MPH. Still no negative effects. Rob gave the radio call and I lined up on finals and did an engine idling full flare landing. Rob said "do a touch and go" so I applied full power and established climb attitude. Much to my horror Rob reaches over and grabs both my wrists and lifts them off the stick and throttle. I very nearly said something I shouldn't. It was only the knowledge that Rob had a lot of experience with the stab that I relaxed. I kept center line by using just a little rudder and we climbed full power to 500'.Rob took over and threw it around a bit and then I lent over and patted him on the shoulder and said "WOW!!!! What you have done to improve an already great machine is fantastic."
Since that time I have done well over 300 hrs testing a number of stabs of various sizes, shapes and placements. Prototype no 5 that we are now flying is the best. I have had students that I have been training as they are building and have had them fly with and without the stab and without exception they have insisted that they have one on their machine. The first one we built was the same as Robs but made out of 1/4" plywood with 2 supports down to the keel on both sides. We flew it and were a little disappointed but we could feel it trying to work but it was flexing too much. I was able to fly that one solo on a nice evening at 50 mph about 7 miles back to my airport join base reduce power, pull on the carby heat and readjust power, turn onto finals and get down to 4 feet without touching the stick. I had only used power and rudder. The next one I changed the shape a little and moved the outer/rear edge forward to stop me hitting my shins when I was pushing the machine into the hanger. This was made out of much less flexible wood but was slightly worse in stability. The next one was the same as Rob's (all the stabs have had between 10 and 12 degrees of dihedral each side) but was shifted back 11 inches. This had been the best one that I had flown. This machine is in central Australia. I went up there to do the final inspection and to finish off my customers training. One day we were doing circuits in a gusty thermally 12 mph wind and I said to Glen let me give you a rest I want to test something. We took off and by 50 feet I had it trimmed in a 60-mph.full-power climb and took my hand off the stick. We climbed to 500' reduced power, skidded around the turns, reduced power to 3500rpm and approached the strip. When we got to 20' I thought that with the higher thrust line if I quickly reduced power the nose might come up but it didn't and I had to take the stick to flare. Well we now have a composite stab without struts and have seen a much more stable RAF. This "effective" h/stab has a neutral airfoil and is possibly 30 to 50 % better than the flat plate variety. Two weeks ago I took the stab off and had it painted. Before I put it back on, one of my students, who has spent his working life as an aeronautical engineer, rang for a lesson. I thought "what a great chance for a test". Mike agreed to fly without the stab and away we went. Poor Mike, he was becoming quite proficient the week before, and now he was working extremely hard, particularly with the power. He was not used to having to adjust power all the time as the nose went up and down in the bumpy air. I was not game to take my hand more than 1/2 an inch away from the throttle in case Mike got behind with power and we would be at the beginning of a power push over. Mike said, "why would people want to fly with that workload?" I told him that with enough training you do get to be able to fly a high thrust line machine ok, but it is quite a while before they can fly in rough weather, and is never as comfortable as with the stab. From a personal point of view the comfort on a 1,2 or 3 hr flight is fantastic. I came home a couple of days ago from a flyin straight into a 30 mph headwind and was able to maintain airspeed of 60 to 65 mph. I have done this trip a number of times and one of those times I had the same conditions, strong gusty headwind without the stab and could only maintain an airspeed of 40 to 50 mph and my throttle hand was worn out by the time I got home.
During the 2 years prior to the "effective" horizontal stabiliser, I had taken a lot of people for a trial flight in my RAF. Quite a number were very disappointed that they did not have much control of the RAF in pitch. I think that a few egos were dented. This was a little discouraging for me because I could fly it quite easily. That was obviously due to my thousands of hours in gyroplanes. What I needed was a RAF that was much easier to fly, so that people could enjoy their trial flight without it being a trial? That way they may be encouraged to come back and have a serious look at learning to fly gyroplanes. I have now achieved what I set out to do. I now have a genuine cross country gyroplane that can be flown for over 3 hours at 70 mph IAS in all sorts of weather, and do it comfortably and most enjoyably.
Well now I am in the process of producing a much-improved RAF style (side by side fully enclosed) gyroplane.
It is a little humbling to think back to how much I did not know, and how people on this forum have nurtured me along. Aussie Paul.
Subject: RAF Stabs
...TEXT DELETED...
Bad Stab Page
Kerneels, Oh dear.
You or somebody else, obviously feels strongly about this, but this is not a contest or a fight, it is a discussion and this is a forum for people to get together. I simply published my first hand experience.
Thanks for the cut and paste, but it is old news and everybody has read it - the link would have been fine.
It is interesting to note that the Helicopter pilot that killed himself only had 9 hours on the RAF. A thousand hours on a gyro does not qualify you to fly a helicopter so why would the reverse be true? Point is that every statement needs to be put in perspective. As with statistics you can make them say what ever you want depending on your point of view.
What I did ask was for, was your credentials to establish if this was your opinion or whether you were just pushing and publishing other peoples opinions? If it is your opinion then you should establish the basis upon which you make your statements..
What flying licence do you have?
Do you own a gyro?
How long did you fly in the standard RAF and was it with an instructor?
How long did you fly in the modified RAF and was it with an instructor?
Did it have a stabilitator or was it the old version?
What kind of HS did it have?
Oh and Kerneels, I am not your "boet", boet!
Some people can reverse park and others not. If the RAF is not for you then move on and find an aircraft that you can fly and feel safe in. There seems to be enough RAF pilots flying RAF gyros safely to make it a worthy aircraft.
Looking forward to your considered response.
Do you own a gyro?
- Gyronaut
braindead wrote: This is the articles ??
I think we are wasting our time talking to someone who doesn't know his singular from his plural. How basic is that?
duh.
Why would we want to discuss the intricasies of gyro performance with someone that doesn't bother to know his 1's from his 2's?
To the RAF boys... move on and ignore the idjuts.
i think the RAF is a beautiful well made machine and in the right hands, of course its safe - the number of hours racked up overall attest to that.
He cant answer the difficult questions flying-i so ignore him.
Len
Lennie boet almal op hierdie forum is nie ingelse nie. Dit is nie my moedertaal nie so ek mag van tyd tot tyd foute maak asJetRanger wrote:braindead wrote: This is the articles ??
duh.
Len
ek daarin kommunikeer.
Jetranger en wat is jou "credentials" boet
Len, jy is blitsig om iemand te probeer verneder en verkleineer.
Miskien is dit n teken van n swak selfbeeld of anders voel jy minderwaardig oor jou aerie,maar kom ons help jou n bietjie reg......'dissappeared' word met net een 's' gespel [09 Maart09] en as jy 'omverskoning' [10Maart09] wil vra, dit is eintlik twee woorde.
Groete.
Groete.
So Top Gun is firing blanks. . . . .
