ENC HEADSETS FOR GYRO'S
I'M flying an open cockpit Gyro, wich Electronic Noise Canselling Headset is the best, and does it work in an Gyro? Is there anybody with some experience on this?
Gyro is koning
Re: ENC HEADSETS FOR GYRO'S
Depends on the radio?
If it is a Filser radio contact Peter How at composite technologies.
Some of these fancy noise cancelling headsets picks up the signal from the aerial. You will end up with a whistle or interference or unreadable.
He suggested that you use what has been proven
ELA – ATR 500 with pilot headsets
Mt03- ATR500 with peltor headsets
Magni – ATR500/600 certain david Clarke models
If you find one that works, please post the details on this site. I have tried a few with different aerials, but could not get any to work properly.
wjkruger
We had a serious problem with noise interference with our standard Pilot headsets on the Ela gyro. Bought the DNC/ANR(ACTIVE NOISE REDUCTION) mouth pieces, from Composite technologies, for the Pilot headsets, fitted it to the standard headsets and problem solved. I can't believe that they don't fit these as standard on all open cocpit headsets.
www.altairaviation.co.za
