The Rotortec Clouddancer project
After identifying a demand for fun among our flying PPL and LSA friends, we (a friend and I) decided to add a gyrocopter to our existing airplane charter. A market survey left only 2 alternatives:
Autogyro Cavalon and Rotortec Clouddancer
Reasons were (amongst other items):
Side by side due to WAF (Wife acceptance factor) and the requirement for Cabin with heating (due to our weather)
Xenon due to poor performance (I have seen a full loaded Xenon needing 800 meters to lift off on a hot summer day) and uncertain company future, was no option.
Rotortec won because off better rotor(4 carbon blades) and engine concept (Rotax lack of power ), dedication to support us and outstanding quality (we visited the factory and met the boss).
Autogyro did not seem to be interested in a buying customer very much (Attitude: We are the best, you can queue up if you want one ) and we did not like the way they treated customer with problems (defects liability etc.)
Due to the new design of the copter it is a risk, but the guys spend years (and a hell of money) to get the proven Weber engine (2 cyl. 750 cc turbo with 135 hp) suitable for this purpose. Copter will be delivered to us around end of July 2012. The copter for our instructor (the blue one) end of May. We started our conversion training for the Gyro endorsement on a MT03 and will then switch to the Clouddancer.
For more technical info: http://www.rotortec.com/index.htm (Alas! German only, english version soon)
135 hp, 12-14 Liter/hour, 249-260 kg, cruse speed above 140, 110 liters wing tank (with anti explo filling), pneumatic prerotor etc.
But check the pictures:
- Air Hog
- The Boss
Re: The Rotortec Clouddancer project
This is amazing fuel consumption! For a 135hp motor.
There is no single perfect gyrocopter and it's always interesting to hear what someone's individual needs and motivating factors are in determining their choice of aircraft. Hope you guys have many many fun and safe flying hours in your Clouddancer. Please keep us up to speed with the build progress and delivery.
regards
Dave
regards
Dave
Dave Lehr
Magni Gyro M22 ZU-EPZ
Engine got fuel injection, overhead camshaft and optimized ECU and small displacement (look, where the car industry is going to). Engine block has been throttled down from 180 hp to 135 hp.Air Hog wrote:This is amazing fuel consumption! For a 135hp motor.
Most of the parts from motor mounts (casted and X-rayed) down to gear box and even wheel rims are produced by the manufacture itself and optimized for weight and stability, Carbon blades are produced together with Eurocopter and were developed with a German technical university.
Developer (Jochen Steinbeck) is a certified commercial Helicopter pilot and got a major degree in chemistry, running a high Tec company since 1995.
Figures were determined by test flights with the prototypes (which were, due to installed sensors and test equipment, much heavier) and published by the manufacture. But we will have the opportunity to get the real data flown under tough conditions (gyro used as a trainer) soon.
Then, I will be able to give you more input and I will be very honest (we are customers and not shareholders of Rotortec) if our expectations will be disappointed.
Hi
""Xenon due to poor performance (I have seen a full loaded Xenon needing 800 meters to lift off on a hot summer day) and uncertain company future, was no option.""
I think this is partly due to German registered Xenons being restricted to the bottom of the range "Xenon R" using the Rotax 912ULS - approx 100 HP
The biggest seller is the "Xenon RST" using the more powerful Rotax 912 RST turbo - approx 115 HP - many of this version operating in South Africa
There are also half a dozen "Xenon RT" using the 914 Turbo - approx 122 HP
The CD looks a great new project - enjoy.
Steve
Steve
Steve_SP wrote:Hi
Steve
- Pieter Smith
Baie baie mooi! Baie sterkte, geniet elke oomlik. Veilig vlieg.
PS: Net jammer vir daai groot stert!!!!!
Wow, that blue and black one looks stunning!!
What is the difference between the 2 and 4 bladed ones, seeing that the 4 bladed one has now flown?
What would the price for the II be, and what is the 19% MWST, a tax? Would that be applicable when exporting?
Whirly.
Whirly.
Mwst. = Mehrwersteuer,Mehrwert= value added, Steuer = tax -> Is GST or VAT (how ever you want to call it I do not see any value by paying an added tax). Only applicable for German residents.whirly wrote:Wow, that blue and black one looks stunning!!![]()
Whirly.
4 blades: faster take off. Less vibrations caused by rotor. Higher drag during cruise.
Less danger of side slip stall. Check YouTube for Rotortec videos.
It is technically possible to remove 2 blades off the 4 blade config, but we are not sure if the official operating permit will be unaffected.
It will start around 65k€ net. Almost everything included. Made in Germany. Pricing is (in the moment) at least 20% less than the the Cavalon (if you compare apples with apples) with much better engine performance. But AutoGyro is the market leader.
Testflight with the exhibition modell
Only possible with this 136 hp turbo engine.
Du to the broad landing gear safe taxi with 50 km was no problem.
Flying impression is like sitting in a heli. Engine noise is much lower than a Rotax configuration. (the full water cooling engine shields)
with the 4 blade carbon rotor the noise will be even lower due to earlier power reduction after takeoff.
Cant wait to see how the 4 blade carbon rotor will take me up.
Me, flying with the designer of the Clouddancer
See, how short the rotor is
- lion
- Solo cross country
What is a side slip stall?okflyer wrote:Mwst. = Mehrwersteuer,Mehrwert= value added, Steuer = tax -> Is GST or VAT (how ever you want to call it I do not see any value by paying an added tax). Only applicable for German residents.whirly wrote:Wow, that blue and black one looks stunning!!![]()
Whirly.
L.
- Vertical Tango
- Look I'm flying
At last you will have the full width hangar to yourselflion wrote:4 blades: faster take off. Less vibrations caused by rotor. Higher drag during cruise.
Vertical Tango wrote:At last you will have the full width hangar to yourselflion wrote:4 blades: faster take off. Less vibrations caused by rotor. Higher drag during cruise.
lion wrote:okflyer wrote:What is a side slip stall?whirly wrote:Wow, that blue and black one looks stunning!!![]()
L.
- lion
Thanks for the reply - hadn't heard of this and will check it out.
