Wiki pretty much sums it up as follows:
Which in plain language I understand to mean; if you want to tilt the disc down the control input is made 90' degress earlier - and this input occurs thanks to the offset position of the Y-shaped rotor-head fork in gyros?Gyroscopic precession also plays a large role in the flight controls on helicopters. Since the driving force behind helicopters is the rotor disk (which rotates), gyroscopic precession comes into play. If the rotor disk is to be tilted forward (to gain forward velocity), its rotation requires that the downward net force on the blade be applied roughly 90 degrees (depending on blade configuration) before, or when the blade is to one side of the pilot and rotating forward.To ensure the pilot's inputs are correct, the aircraft has corrective linkages which vary the blade pitch in advance of the blade's position relative to the swashplate. Although the swashplate moves in the intuitively correct direction, the blade pitch links are arranged to transmit the pitch in advance of the blade's position.
So, if this is correct... how the hell do you fly one of these?
If I'm understanding the theory of gyro precession correctly, and in the absence of offset input linkages .i.e direct input - you'd need to make 90 degree offset inputs to the direction you actually want to go ???? E.g forward stick to roll left, aft stick roll right
Or am I smoking something?
