Sorry for the misunderstanding on my part John
Again, yes it is direct north south routings that will always be a bit "hazy".....communication no less important though.
Apart from my mistake in training, where I totally misunderstood this rule, (hence the topic),... I have never since had to change to 1013 QNE because 1500ft agl is about 300-500ft higher than I normally cruise...
Dont really have a good answer to your question...I can see the danger you pointed out.
Semi Circular Rule?
- John.com
Re: Semi Circular Rule?
Hi Alan,Bundy wrote:Sorry for the misunderstanding on my part John
I figured there was no better person to bounce this off than Jim Davis, so I PM'ed him today and, true to tradition, Jim was very quick to respond with this answer:
"Hi John, good to hear from you.
You are quite right - in the first example, 181 and 359 puts them both at Even +500, and the others are both at Odd+500. And remember they are based on MAGNETIC TRACK.
I understand that in Israel, which is a thin NS country, this problem was so frequent that they actually moved the split round 90 degrees so that it happens on the 090/270 axis.
Jim"
So, indeed, the semi-circle rule does become a concern when flying at the extreme 'edges' of the semi-circles!
I hope this helps!
Many thanks to Jim!
Safe Skies!
John.com
John Comley
Magaliesberg, South Africa
