Rotax Rev Counter Problems
Bushpig
Postby Bushpig » Mon Jan 19, 2009 6:40 pm
Howzit guys.
This weekend I had trouble with my 503 rev counter. On Sat evening when I shut down it was 100%. On Sun morning the guage would show approx 1500rpm when I was at full power. It would move from 0-max1500rpm. I have checked the wiring as best as possible without stripping anything down- from the engine to the back of the guage? Mags are 100%- the revs do drop when doing a mag check.
What could the problem be? Any takers?
Thanks.
BP
AQUILLA ZU-DOJ
Tracer
Re: Rotax Rev Counter Problems
Postby Tracer » Mon Jan 19, 2009 6:58 pm
I have experienced same sort of symptoms on my 503 before. I moved the battery earth wire to a different and more suitable place on the motor and all is well.
Bushpig
Postby Bushpig » Mon Jan 19, 2009 7:34 pm
The confusing thing is that it is regestering rpm but just not fully. Shurely if it was a loose wire or an eatrhing problem it wouldnt work at all, or at best intermittently?
AQUILLA ZU-DOJ
priester
Postby priester » Mon Jan 19, 2009 8:07 pm
Had the same problem on a 582 - the stator coils was the cause. Was also difficult to start.
gertcoetzee
Postby gertcoetzee » Mon Jan 19, 2009 8:43 pm
Coils
But this from someone who thinks there is a ganja pin somewhere in the rotax...
Postby Boet » Mon Jan 19, 2009 8:58 pm
Buy new coil.
Postby Morph » Tue Jan 20, 2009 8:44 am
Your coil could be starting to disintegrate. This happened to CLU-less and bits and pieces of the coil and plates broke off and were swirling around inside the coil section. This resulted in one of the ignition systems failing and the second was already badly damaged, but miraculously working. I would not fly until you pull the stator plate off and have a good look
Then if that is all fine, check your earth, could be corroding etc
Bushpig
Postby Bushpig » Wed Jan 21, 2009 5:58 pm
Thanks guys.
I take it the coil that needs to be replaced is around R5000???
Is there a post on the forum with details on how to go about replacing it?
Thanks again for all the help.
BP
AQUILLA ZU-DOJ
Postby Morph » Thu Jan 22, 2009 12:08 pm
Don't buy anything until you have inspected the old one. This document describes the strip down and reassembly
Rebuilding 503 motor.doc
(75 KiB) Downloaded 12209 times
