Garmin 296C Programming
Please advise, if I get a secondhand unit from the UK,is it possible to have it configured for Southern Africa and can I do this myself thru the internet or will I have to send it to an agent to be done????????? Mother Xmas going shopping so needs to know.
Re: Garmin 296C Programming
I think you can order the unit with the SA map installed or on cd rom in the uk.
Z-MRP wrote:Please advise, if I get a secondhand unit from the UK,is it possible to have it configured for Southern Africa and can I do this myself thru the internet or will I have to send it to an agent to be done????????? Mother Xmas going shopping so needs to know.
I'm sure the SA database can be loaded here. Phone century avionics
ZU-BFS Aquilla
ZU-SMC Cheetah
Benoni
Impukane Nkwazi
MISASA Treasurer
ZU-SMC Cheetah
Benoni
Impukane Nkwazi
MISASA Treasurer
IIRC can be done online. $49.95 last time I did it,but mine has atlantic database, so was just update...
From website...
Awesome piece of kit.....
PS
I think the UK uses same database as we do?
From website...
Am sure you could add maps on data cardsPlease Note: Garmin aviation units can only hold one Jeppesen database coverage area at a time. When you update your database, the old one is erased.
PS
- Rudix
- The Boss
Yes, the UK uses the same (Atlantic) database as we do so you don't need to change anything.RV4ker wrote:IIRC can be done online. $49.95 last time I did it,but mine has atlantic database, so was just update...
From website...Am sure you could add maps on data cardsPlease Note: Garmin aviation units can only hold one Jeppesen database coverage area at a time. When you update your database, the old one is erased.Awesome piece of kit.....
PS
I think the UK uses same database as we do?![]()
Thanks for the info, now to get my hands on a unit. I have a Lowrance Airmap 100 at the moment, nice unit but would like upgrade to bigger screen is the plan
