Cowling Mod
Massimo
Cowling Mod
Postby Massimo » Wed May 21, 2008 8:49 am
Morning All,
I need to modify the fiberglass cowling for the aerie we building. Can anyone suggest who i can take this too for the mod?
In Jhb. :roll:
Re: Cowling Mod
Postby Tumbleweed » Wed May 21, 2008 2:29 pm
I'm not sure if you'll come right with this, but if you want to see the most professional and demanding fibreglass moulding, then go to the company at Sebenza, Edenvale, who make and manage amusement park rides./ Gold Reef City e.t.c. Real pro.
James Bentley
Re: Cowling Mod
Postby James Bentley » Wed May 21, 2008 3:14 pm
I am able to assist, one problem though, I am in Pietermaritzburg!!
James
Airfield EVA'S FIELD
Home EVA'S FIELD
Work Pietermaritzburg
flykr
Re: Cowling Mod
Postby flykr » Wed May 21, 2008 4:12 pm
What type of mod do you require? Adding dumps, blisters and vents is relatively easy to do if you know how to work with glass. :lol:
Massimo
Re: Cowling Mod
Postby Massimo » Wed May 21, 2008 4:59 pm
thanks gents,
Flykr that just it i want to modify position for vent for radiator but ive never worked with glass in my life and i really want it to look great as its the nose of the aerie. Current one look really cr.......
flykr
Re: Cowling Mod
Postby flykr » Thu May 22, 2008 9:09 am
Where you building? I'm located in the south of JHB (Kibler Park) I will gladly come assist you as long as you're not a 100 miles away. :) If you can build an aeroplane then you can learn to work with glass, it's easy once you learn the basics. :wink:
Alternatively you can contact Peter Eick (0829535488) and he will do it for you.
Massimo
Re: Cowling Mod
Postby Massimo » Fri May 23, 2008 2:06 pm
Thanks Flykr,
Building in Alberton so close to you. We having a meeting next week to discuss the motor and after that i should have more direction and can take it from there. Ill also give Eric a call.
Mnr.
Massimo
Re: Cowling Mod
Postby Massimo » Fri May 23, 2008 2:07 pm
Ooops make the Peter Eick
flykr
Re: Cowling Mod
Postby flykr » Fri May 23, 2008 3:30 pm
No problem. PM me if you need a hand.
What plane you building?
