What is a "short block" 582? Are there "long blocks"? Obviously this refers to types of Rotax 582's.
Cheers,
Tony
"Short Block"582
"Short Block"582
Maintaineth at all times thy airspeed, lest the ground rise up and strike thee
Re: "Short Block"582
A 'short block' is typically everything between the sump and the cylinder head (crank, crank case, cylinders, pistons, etc.).
A long block is basically a complete engine (excluding ancillaries like carb, alternator, etc).
