582 cooling system
Sad-Ham
582 cooling system
Postby Sad-Ham » Tue Dec 18, 2007 12:46 pm
Anyone got any advice on this?
What is the best way to flush out a 582's cooling system and what is the correct ratio of anti-freeze/water to refill it with?
Aquilla II ZU-DJS
Wingfield - 124.8
John Young
This is how I drain, flush and refill the cooling system.
Postby John Young » Tue Dec 18, 2007 6:38 pm
Hi Sad-Ham,
This is how I drain, flush and refill the cooling system on my 582 Aquilla once a year.
1. Remove bottom hose from radiator and drain into a bucket. Bend bottom hose down and have someone lift the front wheel of the trike to get last 200ml.
2. Replace bottom hose (loosely), fill cooling system with clean water – approx 3 litres and run engine for under 1 minute.
3. Repeat step No. 1 and drain again.
4. Refit bottom hose and tighten and fill cooling system with a 50/50 mix of cooling inhibitor (anti-freeze) and water. Solo Wings sell it premixed.
5. Run engine up to normal operating temperature, switch off and let engine cool for a few minutes and check coolant level – top up as necessary. You may have to top up a few times during the next pre-flight routines.
Tips and suggestions: -
a. The term anti-freeze is a misnomer. Yes, it does reduce the freezing point by a few degrees, but its primary purpose is to serve as a cooling inhibitor (conditioner) preventing corrosion.
b. The cooling inhibitor (anti-freeze) is toxic – dispose of the drained fluid where you never want to see grass / growth.
c. Be sure to clean all parts of the trike where the drained fluid has made contact – it is highly corrosive.
d. Don’t forget to drain and flush the expansion bottle as well.
Good luck!! :wink:
John ZU-CIB
Postby Duck Rogers » Tue Dec 18, 2007 7:43 pm
I know Johnnie Boy was waiting for me to comment :D
I can't comment on the flushing procedure that John uses but it sounds fine to me. What I can comment on is the "antifreeze"
Make sure you get something that contains a high percentage (90% or more) of Mono-glycol. Stay very far away from anything that's labelled Polyester-glycol. Rubbish stuff with low lubricating properties, that.
Next, use only distilled water (you knew that, right?) and mix to a ratio of 30/70. That is 30% antifreeze and 70% distilled water. You do not need a mix of 50/50 in South Africa's warm climate and in any event, believe it or not, you may even increase your engine's operating temp. by adding too much antifreeze :shock:
Sad-Ham
Postby Sad-Ham » Wed Dec 19, 2007 8:23 am
Thanks for the advice guys. Will get all the stuff on saturday morning and give it a go.
Aquilla II ZU-DJS
Wingfield - 124.8
Turbo_Boss
Re: 582 cooling system
Postby Turbo_Boss » Thu May 22, 2008 6:31 am
Hey Guys,
My 582 use 3 small radiators. 2 are located on each side of the 582 and the other small one is under.
Just curious, do you know what is more/less the capacity in gallons or litres of the full system?
THX
Isaac
Postby John Boucher » Thu May 22, 2008 8:33 am
Easy ....
Do the flush thing into a known bucket volume and record it in your aircraft logbook! :lol:
I know that is not what you wanted to hear but each type of aircraft may have a slightly different volume per setup - more/less radiators, shorter/longer coolant hoses etc. ($$)
Just had to say something...
Postby Duck Rogers » Thu May 22, 2008 8:34 pm
Bad Nav wrote:Easy ....
You said well........
