Prop pitch and size
Bennie Vorster
Prop pitch and size
Postby Bennie Vorster » Fri Jun 01, 2007 10:35 am
How do I know what is the best pitch to use with my plain. Seems like the revs is running a bit high at cruising speed. :?
Bennie Vorster
083 277 5110
Postby Morph » Fri Jun 01, 2007 10:50 am
One answer, Phone Pieter De Necker. You will need to tell him what ratio reduction drive/gearbox you have. Prop length should be 72 inches for the BB
Be aware increasing pitch will reduce your rpm at cruise but will also reduce the rate of climb.
Tel/Fax: +27 11 793 5235
