VW Type 1 Engine push rod tubes and gaskets
Bosvark
Postby Bosvark » Tue Aug 23, 2016 9:11 pm
This engine has been standing on it's belly since I bought it. I mounted it last weekend on a mock-up firewall on a stand to be able to start sorting out manifolds etc. With it off the workbench I could see underneath it and discovered that the push rod tubes on one side has all been dented inwards in a straight line. The engine seems to have been dropped at the one side on an edge of some sort.
Volkspares sell these at R85-00 but I need to buy a complete gasket set to get the seals for the tubes and the paper cylinder gaskets.
Is there any place where I can source these without having to buy a complete gasket set?
Rhino? Fck the Rhino, save the White Ou.
(met permissie van Gyronaught)
Bosvark
Re: VW Type 1 Engine push rod tubes and gaskets
Postby Bosvark » Fri Aug 26, 2016 10:07 pm
Thanks to some e-mailed advice I got the tubes fixed.
Dankie! (^^)
Postby Jean Crous » Sat Aug 27, 2016 7:17 pm
Glad to hear you came right (^^) (^^)
What happens to one does not matter, how one deals with it does.
Bushbaby S/n 002 (Taildragger)
Powered by Revmaster R2300 direct-drive
ZU-ANI
Bosvark
Postby Bosvark » Sun Aug 28, 2016 9:27 pm
And tube seal also sorted s023
Postby Jean Crous » Sun Aug 28, 2016 9:53 pm
Glad for you Eddie vhpy vhpy (^^)
ZU-ANI
Bosvark
Postby Bosvark » Sat Sep 03, 2016 10:17 pm
Thank you Jean vhpy
