Suggestions for an alternative battery needed, please.
Friction Nut
Postby Friction Nut » Sun Jul 24, 2016 2:12 pm
I run a six cylinder Camit 125 hp engine on a maintenance free gel battery of 12.4 volts and 18 amp/hour. It seems not to be strong enough to handle the engine rotation requirements for starting. I am considering replacing the battery with something with more "cranking power". The maximum battery dimensions should not exceed 220 mm(long) x 120 mm(high) x 190 mm(wide) (lying on it's side) in order to fit in the battery compartment.
Any specific suggestions please?
RV12
Re: Suggestions for an alternative battery needed, please.
Postby RV12 » Sun Jul 24, 2016 5:32 pm
Contact them.
http://www.special-battery.co.za/
Tel : +27 11-425-3447
I installed an EVX12200 a year ago. See if any of these fit your specifications
http://www.batterysolutions.co.za/site/ ... uct_id/612
Friction Nut
Postby Friction Nut » Sun Jul 24, 2016 6:09 pm
Contact them.
Thanks!!
