582 Big End
582 Big End
Recently 3 x 582 engines lost the needle roller big end bearing, pilot side. All in the Cape. 2x Blue and 1x silver. Resulting in damage through out the engine. Is this a weak point and any others out there?
Re: 582 Big End
Some of the pilots in the Cape does not put Filter Oil on their filters, because then it gets dirty.
- thys bas
- I hate bird strikes
Re: 582 Big End
and some fly more than 400 hours without replacing the crank
Re: 582 Big End
As far as I know the cranck needs to be checked at 300 hours, if the run-out is within limits then it can go to 600 hours. I know of 2-strokes with over 1000 hours on the same cranck. It all depends on how one looks after it .
Jean.
Jean.
Re: 582 Big End
Or if one looks after the air cleaners well enough. A friend of mine did well over 1000 hrs in a Thunderbird. Same crank.
